Why can I send but not receive a fax on Imagistics 1630?
2 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: I have an Imagistics 1630
This error is a fatal error. In most cases, it's related to the Heater Lamp inside. It's possible that the lamp isn't working anymore or perhaps it has a faulty. This could be only resolved by replacing the faulty component, i.e. the Heater Lamp. Your only option is to call OCE at 800-243-5556 or alternative you can e-mail them using this form (click HERE.). Fill in all the fields and select "Equipment Maintenance/Service Required" for "Type Of Request".
Also, before you call OCE (FYI OCE = Manufacturer of this machine), note down the model number, serial number, etc.. which they will ask you. They might also ask you the details about it's purchase. Answer them promptly. After reviewing your query, they will let you know what's to be done, but most likely, they will send their man to inspect the machine.
I am sorry that it's not a fixable problem following instructions, but hope this helps. Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Posted on Jun 29, 2011
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Imagistics SX 2100. When you change the drum what
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Jan 25, 2010 | Pitney Bowes Office Equipment & Supplies
How to print Speed dial numbers programmed for Pitney Bowes Fax Model 1630
I believe you press , features 1 , 7 , 3 enter then the send receive key to print.
Aug 25, 2009 | Office Equipment & Supplies
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Imagistics 2500 fax machine bought used - no book - how do I delete name/phone number of prior owner
press menu*2864 in quick succesion, should take you to test mode, enter 01 and then when that is done, enter 99 to exit test mode
Jul 30, 2009 | Brother MFC-8220 Fax
How to connect pitney bowes 1630 to PC
you will a usb cable and driver software.should not have any other problems
May 06, 2008 | Office Equipment & Supplies
PB 1630 fax machine
it sounds like a programming issue, the machine should be auto recieve mode to work properly. but please be more descriptive on make and model and when it gives you the code
mikey
Mar 13, 2008 | Office Equipment & Supplies
16 people viewed this question
k24674
jasbo
jasbo
