Question about Aloha Housewares Dryers
How do you fix a fan that is intermittant
Everything works, but the fan changes speed intermittantly. What can I do to fix this?
    Genius:
  • Aloha Housew... Master
  • 1,617 Answers
Buy a good fan!
Posted on May 07, 2014
Washer makes clicking sound while agitating
you should replace the control panel or get a new washer.
Mar 01, 2014 | Whirlpool Washing Machines
2002 grand caravan blower motor intermittent replaced resistor
in review
the fan speed resistor is new
you bench tested the blower motor
12 volts test ..only runs it at full speed
if cabin filer want changed the blower motor would run hotter
could be the motor brushes or bush/motor bearing when slowed
you might want to inspect the brushes and clean the dust out of the motor
if no better
does that have climate control ?
might be the fan switch itself or the earth isnt so good
Apr 01, 2017 | 2000 Dodge Grand Caravan
Fan speed control working intermittently
most likely blower motor and resistor, replace and recheck.
Jan 08, 2014 | 2005 Buick LaCrosse
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
HVAC Fan Blower Problem
sounds like the blower motor needs to be replaced.
Sep 05, 2012 | 2001 Lincoln Town Car
2006 Toyota Tacoma AC Blower works intermittently
there is a TSB for a noisy blower motor and not working except on Hi, both cover under 36K miles, repair includes replacing blower motor and or resistor block and harness, judging your problem can be a bad resistor block and harness. hope it helps
Jul 30, 2012 | 2006 Toyota Tacoma
Heater fan runs intermittently.
too simple .....3tings the motor bruchs when gets hot loose contact to the rotor and the fan stop working solution ; change the motor 2 the speed regulator mouted on the fan case is ba d change it 3 the heater suitch chek it too nicolas......
Oct 25, 2008 | 2003 Nissan Maxima
Dryers Logo
44 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
john h
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
