Question about Garden
How to change valve guides on a renault 5 ts 1400
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Disconnect battery cable and remove spark plug. Thread a nylon rope into the cylinder and GENTLY raise piston toward top (to push rope snugly against the valve.) Use compression tool on spring to allow valve guides to release. Be prepared to remove cylinder head if you allow engine to turn or if there are any complications.
Posted on May 07, 2014
Tappet clearance on a renualt R5 TS
What is the tappet clearance on a renault 5 ts 1985 model?
Jan 03, 2013 | Cars & Trucks
Hi there; my stihl ts 420 does not start easily
replace the decompression valve. also check for carbon buildup on top of piston. usually when a saw stops on its own after 5 min or so.... the piston and jug are scored and need to be replaced.
Jun 16, 2010 | Stihl Ts 410 420 Cut Off Saw...
Is it normal to have to replace pulley, timing belt and fan belt in renault megane cabriolet after 5 years. How much do these spare parts cost? Have been quoted £750 parts and 6 hour labour costs.
Timing belt on 4 cylinder Renaults should be changed every 50-60000 Km. Consequence of not doing so is having the belt break, and damaging valves and valve lifters (extremely costly) . Replacing the belt is time consuming, and labor intensive. So while the belt is out, its is a good investment to replace pulley, belt tensioner/ roller bearing and water pump belt, which is nearby and has to be taken out anyway, for timing belt replacement. Meganes dont have fan belts, they use electric motors for this duty.
Feb 16, 2010 | Renault 181 Cars & Trucks
What is the timing mark for the ratary valve on a ts 100 think its 1977 year
Install the valve plate so that the timing mark punched on it faces outward and aligns with the valve guide pin set in the crankshaft.
Dec 05, 2009 | 1981 Suzuki TS 185
Renault 5, 87, fitted new water pump, worked ok for a while, now radiator fan doesnt come on car gets very hot, engine shakes whilst ticking over and acceleration is very spluttery, i need advice
change the rad switch thats in the rad ,that will make the fan work ,as for idle and missing ,i would do a compression check and if iam not mistaken it will need a valve regrind and maybe evan new valve springs .the reason i say this is because by its age i dont think renault used stelite coated valves and valve seats for unleaded petrol so you will have to grind the valves in as they will be all pitted and burnt ,and use a lead additive in future
Aug 05, 2009 | Renault R5 Cars & Trucks
Change Faulty/Cracked touchscreen on P900
The screen consist of two parts: touchscreen(TS) itself and LCD screen. They're attached mechanically, not with glue or solder.
TS glued to metal frame and by mean of this frame(mechanically) attached to LCD(like shoebox cover) - you can see pits on side.
1. With sharp blade of razor or scalpel gently remove this frame with TS glued on top.
2. Then remove TS from the frame (I simply broke it and removed glass pieces from the frame)
3. Clean the frame with alcohol to remove glue and grains of glass.
4. Glue new TS to the frame at ONE SITTING!
5. Wipe out dust from LCD and inner surface of TS and attach the frame.
6. Buy conducting glue and connect 4-contacts of TS cable with LCD cable. Put adhesive tape over them to maintain electric connection.
That's all.
Jan 28, 2008 | Sony Ericsson P900
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
