Question about Gateway 7004618 (Black) 17 in. Flat Panel LCD Monitor
Very very dark screen
I have the monitor all hooked up correctly and when i look at it it looks black, when i shine light into it i can just barly see my desktop i played with the brightness of the screen but it didn't do anything to the monitor what can i do?
0 characters
1 Points
The monitor Westinghouse model LCM-19w4 when I turn on the computer the screen remains black even with a green light on and I can use a flashlight to see the screen. When I turn it on and off the scre
It's mostly likely a bad capacitor in the main power supply of your monitor. If you're brave enough to dismantle it, look for capacitors that're "crowned", and sometimes even rupture from overheating in such circumstances. You can order replacements from Digi-Key if you can figure out which might be your problem, but I'm not sure I recommend you try this unless you have at least SOME soldering/desoldering skills or a friend who does. You COULD wind up worse off. It's up to you, only YOU know your personal skill level for such tasks. And do I need to say, UNPLUG it before dismantiling? :)
Mar 16, 2014 | Westinghouse 22" Widescreen LCD Flat Panel...
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Nov 08, 2012 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have a dell inspiron laptop, and a dell monitor hooked up to it, i turn on the monitor and it is very bright for about half a second then it becomes very dark, so dark that it looks like it turned off,...
Does the fault appear on the laptop screen aswell? It appears by your description that the fault is only on the external monitor. If the screen comes on for a moment and then goes blank as described, then this appears to be an invertor fault. It is very common among laptop and tft screens and requires the invertor inside the panel to be replaced / repaired. Simply plug the screen into another computer to confirm.
May 29, 2011 | Rosewill R900J 19" Flat Panel LCD Monitor
Most likely your backlight is out, one way to tell is if you shine a light at the screen you should see whatever is hooked up to the monitor. Another issue could be the LCD inverter which supplies the power to the backlight.
Hope this helps
Apr 11, 2011 | Computer Monitors
I was playing Fallout 3 and after a while, my screen turned a bit darker, not really dark but as if there is a light shadow on it and after a few seconds it turned black. I tried to press twice on the...
try shining a torch/flash light on the screen
If, when the flashlight is on the monitor, the problem is fixed then you have aback light issue.
You will have to contact your manufacture or shop you bought it from
Mar 04, 2011 | ViewSonic VX1940w LCD Monitor
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
My hp pavilion ze5270 notebook works fine except the screen does not lightup so i can see my displayed pages. if i shine a light directly into the screen i can see the page displayed on the screen or i...
well as i see from your problem explanation i believe that the LED which are at the backside of your LCD screen is not working so its better to troubleshoot from that angle.
good luck
Jan 05, 2010 | Computer Monitors
A 20" monitor gets a black screen when turned on
sounds like you might have a back lighting issue? take a flash light and shine it on the monitor when it is black and look to see if the image is there but not lit up, if this is the case then you might need to change the light balist in the monitor of even the back lights themselfs..
if the picture is fuzzy for a long period of time then you have a controler card issue there is a controler card in the monitor that changes the image coming in from HDMI, VGA, DVI into the binary that the vertical and horizontal drivers use to show you the image onthe screen... hope this info helps. good luck
Sep 02, 2009 | Computer Monitors
Gateway 7004618 (Black) 17 in. Flat Panel LCD Monitor Logo
Top Gateway Computer Monitors Experts
 Mike M
Mike M
olayoju victor
Are you a Gateway Computer Monitor Expert? Answer questions, earn points and help others
