SOURCE: gilera 125 xv engine cuts out when reved up
Carb needs cleaned and possibly rebuilt.
Please rate this solution.
SOURCE: my gilera runner vx 125 wont start
i had the same problem if i remember correct it was a T shaped connecter for 3 tubes that had snapped cost about 50p
SOURCE: gilera dna 50cc electrical starting problems. It
it sounds like the bendix on the starter is bad you can try to remove the starter and spin it off of the bike to make sure
SOURCE: where do i put oil in my gilera 125 dna motorcycle
Go to the site below and you can download a free service manual for your bike. Now you can do more than ever before. Use 10w40 motor oil in the gearbox.
http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this answer. Thanks!
SOURCE: When slowing down and coming to a halt the Gilera engine cuts out
ALWAYS have a fire extinguisher at hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slides back in the throat of the carbs, Move the clip on the jet needle one notch lower. Put the rest of the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
