Question about Car Audio & Video
How do I turn off the muting on SX-205 Pioneer receiver to get sound?
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Posted on Mar 07, 2008
tech48
  • 624 Answers
SOURCE: Pioneer sx-205 gives a overload
Does it play normal on any sources, or do you only have the tuner and CD for available sources?
There are many different things that can cause this type of problem.
It could be bad solder connections on in the amplifier circuit or power supply, it could be a bad speaker or a bad output channel inside the receiver if this happens only when it gets turned up loud.
The overload warning happens when the amplifier circuit has excessive current or DC voltage on the outputs. Unfortunately the only way to determain if it is the speakers is to change them with other known good speakers and see if it still happens. But before buying any speakers you need to have the receiver ruled out as the source of the problem.
It can also go into overload if you have the wrong type of speakers connected, or too many speakers connected. Each speaker jack should only have one speaker connected toit. If you are using for example, 4 speakers connected to the "A" speaker jacks meant for just 2 speakers, it will create a load to the amplifier that the amplifier is not rated for.
Look on the back of the receiver and it will have listed the proper impeadance for your receiver. Most will say:
8 ohms or more "A" or "B" speakers
16 ohms "A" and "B" speakers
That means you must use 8 ohm or higher ohm rated speakers if you are using only speakers"A" or only speakers "B", but can not use 8 ohm speakers if you are using speakers "A" and "B" at the same time. Then they must be 16 ohm speakers.
Two 8 ohm speakers in one speaker jack is a 4 ohm load, that is why you can not use more than 1 speaker per speaker jack.
I hope you found this information useful, and if I can be more help just let me know.
Dave
Posted on Jun 28, 2008
SOURCE: pioneer sx-315 receiver stays in phones in mode and no sound is coming out of my main speakers
Simply stick the tip of a screwdriver in the input and it will reset. (:
Posted on Feb 28, 2009
SOURCE: Looking for replacement remote for Pioneer sx-205
The Pioneer SX-205 does not have remote control capabilities.
Posted on Nov 05, 2009
  • 3247 Answers
SOURCE: My Pioneer Receiver (SX-255R) won't
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Posted on Jan 02, 2010
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
Blown Fuse / SX - 205 / Pioneer reciever
Check the area where the fuse was...it's usually marked on the board or next to the fuse holder. Check the size also, 2 types 5x20mm or 1/4x1 1/4 in. Usually slow blow.
Mar 30, 2010 | Pioneer SX-205 Receiver
Pioneer Receiver SX-205 flashing ''overload''? Nothing in owner's manual troubleshooting chart.
usually it is a technical indication of the output being shorted. disconnect all speaker wires and try again. still blinking?
Mar 06, 2010 | Pioneer SX-205 Receiver
"muting" shows up the screen and I no longer get volume, can not the muting off as I can not see where I would change that setting.
Are you sure it's not the TV telling you that it's muted? I went down the tubes on that one myself.
The receiver's Mute can be defeated by just rotating the volume knob upward. Ditto with TV's.
May 11, 2009 | Pioneer SX-205 Receiver
SX-205. Left channel doesn't work.Internal problem. Should I change any semiconductors / transistors,diods or other/? How to find out,which semiconductor is bad? Please,help me.
Check the final output relays first. They are mechanical and have been known to fail after so many cycles. The click you hear about 3 seconds after you push the power button are those relays.
Apr 04, 2009 | Pioneer SX-205 Receiver
PIONEER SX-205. Left chanel out of order. How to solve the problem?
You haven't mentioned what you have done to isolate the problem so I have to ask some stupid questions.
Is the Left Channel failing no matter what source you select?
N: Source problem / Identify the source and ask another question with new data
Y: continue...
Turn the receiver OFF.
Toggle the Tape Monitor Switch up a number of times to wear off any oxidation. Any change?
While you're at it, toggle, twist and operate every control throughout its range for the same purpose. Lower the volume.
Turn the receiver ON.
Tune an FM station.
Swap the Left Speaker leads and the Right Speaker leads at the receiver. Did it move with the speaker?
Y: bad speaker or wire
N: internal receiver problem.
Apr 03, 2009 | Pioneer SX-205 Receiver
I have a Pioneer SX 251R and a PD M501
How about a Pioneer CT-W302R stereo double cassette deck ?
I have a unit in very good condition for sale.
lftremblay@hotmail.com
Feb 16, 2008 | Pioneer SX-205 Receiver
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
