What needs to be removed in order to replace drive belt? How best to do this and are there any special tools required? The belt was dry and very hard so I assume the only problem is the belt itself, but could there be an unlying cause?
TIA
when this washer spins, it sounds like something is rubbing against something. That is the best way...
(More)
when this washer spins, it sounds like something is rubbing against something. That is the best way I can explain this. It is louder than a regular spin sound but still spins good but I know this means something is going wrong.
hola yo desmonte la pieza quisiera saber si exite un ejemplo de como debe quedar la correa [puesta...
(More)
HOLA YO DESMONTE LA PIEZA QUISIERA SABER SI EXITE UN EJEMPLO DE COMO DEBE QUEDAR LA CORREA [PUESTA EN LA MAQUINA
What does the newly mounted drive belt look like? Would love a photo showing it. There is a rubber...
(More)
What does the newly mounted drive belt look like? Would love a photo showing it. There is a rubber thing and I cannot tell whether or not to weave one side of both sides of the new belt around it. The belt seems a little loose when I just loop it around both pulleys. I have the service manual from on line, but the pictures are not clear. Thanks for any help
and the drum will not turn by hand. what is preventing the drum from turning? is this an easy fix i...
(More)
AND THE DRUM WILL NOT TURN BY HAND. WHAT IS PREVENTING THE DRUM FROM TURNING? IS THIS AN EASY FIX I CAN DO ON MY OWN? ANY SPECIAL TOOLS REQUIRED? TIA
amana washing machine about 10 years old. i have it partially tore apart. ihave removed inner tub....
(More)
amana washing machine about 10 years old. i have it partially tore apart. ihave removed inner tub. what are the remaing steps to get to the seal and bearing assembly?
