How do i troubleshoot my first data fd100 terminal?
Terminal has been in storage for 3 years. It worked when taken out of service. It will not power up now (meaning that the screen is blank and no other indication of power on), however the FD10C keypad will power up when hooked to it.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
Select 6, then 3, then 1, then 1, then 4 is lower contrast, 5 is raise contrast, 6 is save. if you press 4 and it changes the screen keep using 4 and 5 to get to desired contrast press 6 to save. press clear 4 times to get to main screen. if this does not work, unplug power source and then wait 1 min and plug back in.
the terminal and pinpad are no longer supported and may not work properly since they are outdated.
visit firstdat.com/demos for additional help
Posted on Jan 07, 2015
Paragon model 8141-00 defrost timer wont turn.
Is this a used timer?
8141-00 is 120 volt timer.
Is your 120 volt Hot wire on terminal 3 and Neutral on terminal X?
Test across 3 and x for 120 volt.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Don't buy used defrost timers... they always look good when you inspect, but never work when connected... that's why the timer was taken out of service and sold as used timer.
Save the old trippers for use on new timer.
Gene
Water Heater Timers Save Money
Mar 28, 2015 | Paragon Hardware & Accessories
Why does a bus er code comes up on my 2007 Harley Davidson ultra glide
"BUS Er" indicates Serial data bus shorted low/open/high. It is number 1 priority DTC fix
If speedometer reads "BUS Er" with the ignition key turned ON with the run/stop switch at RUN with the engine off, check the data bus for an open or short to ground between the data link connector [91A] terminal 3 and ICM connector [10B] terminal 12 on carbureted models, AND on EFI MODELS, ECM connector [78B] terminal 5 , TSSM connector [30B] terminal 3, speedometer connector [39B] terminal 2 or if a tachometer is installed, tachometer connector [108B] terminal 2.
Also check for an open diagnostic test terminal between the data link connector [91A] terminal 3 and the TSM/TSSM connector [30B] terminal 3. With the ignition key turned ON, serial data bus voltage should be typically 0.6-0.8 volts. The range of acceptable voltage is 0-7.0 volts.
Wiggle the instrument and/or vehicle harness to identify possible intermittent problems.
Jul 11, 2014 | 2006 Harley Davidson FLHTI Electra Glide...
First data fd100 won't power up
  1. Make sure you push that tip fully into the side of the FD100 with your thumb (these are notorious for falling out- that's why they designed a clip on the back corner)
  2. Try a different power source (outlet)/surge protector (make sure its switch is ON/wall plug (different names for same objective) You'd be surprised how many of those can be faulty-EVEN IF other things are working that are connected to the same one, THAT particular one may be faulty, or it could be barely too much load, etc. etc.!!!.Very difficult to prove or trace this type of fault.
  3. Try a different power supply/ power cord/transformer (different names for same part) They can go out, sometimes from a surge, lighting, etc.
  4. If none of that solves it, I am afraid you may have a dead FD100 :(
May 06, 2014 | ePaymentSolutions First Data FD100 Credit...
First data fd100 reset
by reset are you wanting to erase the information in terminal or just reboot.
for reboot unplug power for 1 minute plug back in
Jan 24, 2014 | VeriFone OMNI 3200 (P092-101-10) Printer
My first data fd100 wont power up
check the power cables and the power source, make sure all are secure in place.
the terminal needs a power source that came with it, make sure you are using that one.
call msp if you need additional power supply
Jul 01, 2013 | ePaymentSolutions First Data FD100 Credit...
Without doing the minimal setting test to see if a time clock works how do you test a time clock with defrost termination the x terminal
8145-20 is 240Volt defrost timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
You are testing the 8145-20 timer.
The timer dial should rotate continuously. Trippers on dial rotate around. When they reach the trip switch, the timer starts the defrost cycle.
Terminal 3 has power during defrost cycle.
Terminal 4 has no power during defrost cycle.
With 240Volt timer, terminals 1 and 2 and N and X test for live power to ground at all times.
The limit switch is connected to terminal X and to terminal N.
During the defrost cycle, the limit switch measures the pressure or temperature.
When pressure or temperature reaches the set point, the limit switch closes the circuit and this trips the solenoid inside timer. The solenoid turns off the timer relay, and the defrost cycle ends.
At this point the timer turns off the defrost, and sends power to the refrigeration.
Terminal 3 has no power during refrigeration cycle. (The opposite of defrost cycle).
Terminal 4 has power during refrigeration cycle.
Test these terminals for power to ground. One or the other should have power at all times, but not both.
If timer will not enter defrost cycle, make sure the X-3596 trippers are not worn down.
Disconnect the wire to terminal X and see if defrost cycle will start.
Test terminals 3 and 4 again and see if removing wire from X caused a change.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Paragon 8145-20 Defrost Timer
When power is applied load one reads o.k. load two reads zero why?
You posted under EH40 240Volt programmable timer.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
If I understand correctly, you are testing the terminals when timer turns ON?
Test shows 120V between terminal 4 and ground wire.
Test shows 0 volts between terminal 6 and ground wire.
Solution:
Test terminal 3 to ground -and- test terminal 5 to ground and make sure each tests 120V.
Test terminal 3 to terminal 5 for 240V.
If terminals 3 and 5 test correctly, but terminal 6 never has power, then relay inside timer has gone bad.
Contact Intermatic about 1 year limited warranty
http://www.intermatic.com/customer%20service.aspx
Upvote the help.
May 28, 2011 | Intermatic EH40 - Electronic Water Heater...
WH40 water heater timer: Does black wire from service box go to terminal #1 and black wire to water heater to terminal #2? Does neutral (white) from service box go to terminal #3 and neutral (white) to...
WH40 is 240Volt timer.
WH40 will not work with 120V circuit.
See WH40 wiring illustration at following link:
There are two hot wires in 240V circuit because every circuit requires two wires to complete the circuit.
Hot wires from breaker connect to terminal 1 and 3.
Notice that small white wires are also connected to terminals 1 and 3.
Small white wires power clock motor located on back of mechanism, so this says power from breaker box must arrive on terminals 1 and 3. This insures that clock motor runs continuously.
If clock motor only runs when manual override switch is clicked ON, then your Hot and Load wires are reversed.
Bare ground wire connects to green ground screw.
Wires going to Load (water heater) connect to terminals 2 and 4.
FYI: Terminal A is not used unless circuit also has a Neutral wire,
See basic water heater circuit Diagram #2:
http://waterheatertimer.org/240-v-water-heater-circuit.html
Terminal A is also used if you want to convert WH40 to 120V timer by replacing 240V clock with 120V clock.
How to convert Intermatic 240V timer to 120V timer
http://www.fixya.com/support/t7353947-intermatic_timer_wg
Dec 24, 2010 | Electric Intermatic Inc Wh40 Water Heater...
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
Dryer plug issues
for 3 wire Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
for 4 wire Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Jun 09, 2008 | Frigidaire GLER642A Electric Dryer
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
