Question about Campbell Hausfeld Fp209501
Campbell Hausfeld FP209501
How to connect hoses
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: need owners manual for campbell hausfeld vt6275
go to chpower.com and type in your model number under the header needing manual and it lists several different options for you. Hope this helps and if I have helped you with your request would you please rate this response accordingly. Thank you.
Posted on Nov 21, 2009
  • 4088 Answers
SOURCE: I have a model FP209501 Air Compressor 2 Gallon,
The spray gun consumes more air volume than the compressor can deliver. You can pause painting periodically to allow the compressor to 'catch-up' or buy a larger delivered-volume compressor. The compressor that you have was intended to supply air for pneumatic nailers and staplers in an intermittent fashion. Hope this helps!
Posted on Jan 18, 2010
  • 3 Answers
SOURCE: Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Posted on Oct 31, 2010
The safety valve blow out when it reach 110 pound
If the safety valve blowS out when it reachES 110 poundS, it is either the safety valve or the gauge is wrong and there is more than 110 psi.
Feb 04, 2014 | Campbell Hausfeld Fp209501
Compressor does not shut off
compressor has a defective pressure switch
Oct 25, 2013 | Campbell Hausfeld Fp209501
Air compressor won't build pressure, continuous running.
reed valve in compressor head is leaking and or the check valve is stuck open.
Aug 26, 2013 | Campbell Hausfeld Fp209501
Hookup
For the Campbell Hausfeld 1800 PSI model (PW182500AV), the garden hose connects to the pump inlet on the lower back of the pressure washer. The high pressure hose connects to the high pressure outlet on the lower front of the pressure washer. Here is the operator's manual that will show both connections. http://www.mowersatjacks.com/images/campbell-hausfeld/manuals/pw1825.pdf
May 18, 2013 | Campbell Hausfeld 1800 PSI Electric...
Looking for campbell hausfeld airless spray gun ps220a 2/3 hp operators manual Please!
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support" tab select 'Manuals/Parts Lists. Do a search for your model number and you'll be presented with the manuals and parts lists for that line of paint sprayers.
Feb 28, 2013 | Campbell Hausfeld Airless Spray Guns &...
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
Campbell Hausfeld Fp209501 Logo
49 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
