Question about Bosch Washing Machines
WFO2864GB/01 will not spin
Why will my WFO2864GB/01 not spin?
  • 957 Answers
FIRST IS THE WATER PUMPING OUT WHEN WASH IS DONE AND IT SWITCHES TO SPIN? IF NOT THEN IT WILL NOT SPIN YOU HAVE TO GET RID OF THE WATER FIRST. IF IT IS NOT PUMPING OUT THEN THE PUMP MAY BE THE PROBLEM.
Posted on May 07, 2014
Bosch Washer WFK2401UC/01 Does not spin. Replaced Power cir. Bd. Turned on started right up. completed cycle. Went to wash this morning Drum will not spin
Sometimes the brushes on the motor get worn and they cause motor to act intermittently. I changed my brushes and this corrected the problem of not washing or spinning.
Dec 11, 2014 | Bosch Washing Machines
How do I use the spin button on bosch
Each time you press it within a cycle program it toggles through the different speeds
Sep 26, 2014 | Bosch Washing Machine Control Panel...
Problem(s?) Bosch WFO2864GB/01
check the 13a fuse in the plug if you have a heater fault it may well have taken the fuse out as well as the rdc the machine will also need checking to resolve the issue rcd's are very sensitive with most having a trip current of only 30Ma although the heater is first thing to check
Mar 03, 2014 | Bosch Washing Machines
My maytag Epic Z washer won't spin. Flashed F-01
f1 is a bad control board,you can try unplugging the dryer for like 5 minutes and then plug it back in,sometimes that will reset the board but most likely you'll have to replace the board.
Feb 12, 2018 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Changeing rear pads on 01 cabrio glx
You need to spin the caliper piston while puching in to retract the caliper, theres a tool used to do this easily, you can get this tool at most parts stores
Jan 15, 2009 | 2002 Volkswagen Cabrio
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Spin problem
WHEN ON SPIN CYCLE.. IT TRIES TO SPIN AND AGITATE AT THE SAME TIME
Sep 30, 2008 | Washing Machines
Open Questions:
Bosch Logixx 8 washing machine Powers OFF itself when filling water in the softening stage I have a 7 years old Bosch WAS32742AU/08 washer, it will wash, rinse then will power itself OFF with nothing on the display when it reaches the softening cycle where it begins to fill water, there is about 10mins left in the cycle. I can turn the dial OFF then back to the same program to resume the cycle, it will start filling with water again in the softening stage and power off again. I've checked the water level pressure switch hose and cleaned the chamber, I dont't think there is a problem with that because it works during the cycle until the softening stage. I can run and complete the Drain only cycle, Rinse only cycle, Spin only cycle and 15min Quick cycle without interruptions. It's only programs that has the Softening part of the cycle it powers off when filling water in the middle dispenser compartment during the softening stage where Valve 1 and Value 2 are open. I don't even use softener and the compartment is clean. The current work around is when it Powers OFF during softening, I turn the dial to OFF then select the rinse only cycle to complete the washing. I got into the Valve test mode and found that Value 1 and Valve 2 tests are OK individually but when it V1 and V2 are both ON to fill the middle softener dispenser compartment it wont stop filling and eventually the machine powers off. I posted a video of the test here: https:/ / streamable dot com/n1gw6 https:/ /player dot vimeo dot com/video/264199360 Do you know what the problem could be?
Apr 11, 2018 | Bosch Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
