Question about Brother MFC-5440CN All-In-One InkJet Printer
'1) Lost' Black print 2) Can no longer scan more than one page
1) I was scanning multiple pages and some sheets became jammed in the feeder. The pages came out easy enough however afterwards te Black ink will not work. tried cleaning plus a test print just shows blue, yello and red. Also reinstalled printer but no good
2) I have only been able to single sheet scan for some time - no idea why this has happened as was perfectly OK until a few weeks ago
Both problems in respect of Brother MFC 5440 CN - Thank you for your help. Regards. Paul
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Posted on Jun 23, 2009
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
Jam in top 3015d
Sir/Madam
Occasionally, media becomes jammed during a print job. An error in the software program and a jam message on the printer control panel display indicate a media jam. To prevent a jam, see the following instructions:
  • Only print on media that meets HP specifications.
  • Only print on media that is not wrinkled, folded, or damaged.
  • Make sure that the printer is clean.
  • Make sure that the input trays are loaded properly and are not too full. See the start guide for more information about loading input trays.
When adding new media, always remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, which reduces media jams
Clearing a media jam
CAUTION: Media jams might result in loose toner on the page. Use cold water to wash toner off of clothes, as hot water will permanently set the toner into fabric. To remove toner from hands, wash hands in cold water.
CAUTION: Do not use a sharp object, such as a pencil or scissors, to remove jammed media.
NOTE: When clearing jams, including jams in the output bin, always push the print-cartridge-door release to open the top cover, and remove the print cartridge. Keep the top cover open and the cartridge out until the jam has been cleared. Opening the top cover and removing the print cartridge relieves tension on the printer rollers, which makes removing jammed pages easier.
Push the print-cartridge-door release and open the top cover.
Figure 1: Pushing release and opening top cover
Grasp the handle of the print cartridge and remove it. Set it aside.
Figure 2: Removing print cartridge
CAUTION: To prevent damage to the print cartridge, do not expose it to light any longer than necessary. Place the print cartridge in a paper bag or other opaque container until it can be placed back in the printer.
With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the device.
Figure 3: Jammed media most visible
When the jammed media is removed from this area, replace the print cartridge.
Figure 4: Replacing printer cartridge
Press the supporting springs, and close the top cover.
Open the media input tray and remove any media from the tray.
Slide the media guides inward as far as they will go. Press and hold down the tabs inside the media input tray, and slide the media input tray out of the printer.
Figure 6: Removing media input tray
Replace the input tray into the device.
Figure 7: Replacing input tray
After clearing the media jam, it may be necessary to shut down the printer, and then turn it on again.
NOTE: To add new media, remove all of the media from the input tray, straighten the stack of media after adding the new media, and then place the stack in the tray.
Clearing other media jams
If the media has jammed where it exits the printer, grasp the leading edge of the media and pull the media out through the output bin.
Figure 8: Removing jammed media from output bin
NOTE: If the printer is shut off before clearing the media jam, turn it on again, and then restart the printing or copying job.
Tips to avoid media jams
Make sure the automatic document feeder (ADF) media lever is in the correct position for the media being used. Slide it to the single-sheet setting (to the right) when scanning on thick media. Slide it to the multiple-sheet setting (to the left) when scanning on regular media.
Make sure that the input tray is not overfilled. The input tray capacity varies depending on the type of print media that is used.
Check that the input tray is securely in place.
Do not add print media into the input tray while the printer is printing.
Use only HP-recommended media types.
Do not let print media stack up in the output bin. The print media type and the amount of toner used affect the output bin capacity.
Check the power connection. Make sure that the power cord is firmly connected to both the device and the power supply box. Plug the power cord into a grounded AC power outlet.
Media jams occur in the automatic document feeder (ADF)
Occasionally, media becomes jammed during a copy, scan, or fax job.
A software error message indicates a media jam, and the Doc feeder jam Clear, Reload message appears on the printer control panel display to indicate a jam.
  • The ADF input tray is loaded incorrectly or is too full.
  • The media does not meet HP specifications.
Typical automatic document feeder (ADF) jam locations Input tray areas: If the page is sticking out of the input tray, try to remove it gently from the input tray without tearing the page.
Figure 9: Removing jammed media from input tray
Output paths: If the page is sticking out of the output bin, try to remove it gently without tearing the page.
Figure 10: Removing jammed media from output bin
  • Intermediate location: If the page is sticking out of the input tray and into the output area, see "To clear a media jam from the automatic document feeder (ADF)" below for instructions.
Automatic document feeder (ADF) media lever If a thick media is being used, slide the media lever to the single-sheet setting (to the right). Load a single sheet of media into the ADF.
When the copying, scanning, or faxing jobs are complete, slide the ADF media lever back to the multiple-sheet setting (to the left).
Clearing a media jam from the automatic document feeder (ADF)
  1. Using both hands, pull the printer control panel door toward you.
    Figure 11: Opening printer control panel door.
  1. Remove any jammed media. Figure 12: Removing media
NOTE: Use only your hands to remove jammed media. Using other objects can damage internal parts.
Make sure that all of the pieces of media are removed, and then close the printer control panel door.
Figure 13: Closing printer control panel door
I Hope Your HP Printer Problem Resolved By Now,In Case You still Having HP Printer Problem Then Visit Official HP Printer Website Below Link URL:
HP Printer Issue:
HP Support document HP Support Center
Or
If You still need HP Printer assistance Then Follow Us On :
HP Printer Support
Feb 13, 2014 | HP LaserJet Enterprise P3015d BW laser...
My scanner just started smearing the first page of a duplex to pdf but when I scan just front of document it doesn't smear it
Hi
Your question is not clear.
Sometimes using technical jargon makes it harder for people to understand each other (this applies to both askers and answerers).
I always advise askers to use normal language as much as possible and answerers to do the same and where jargon is unavoidable, to explain as they go along.
Please post again to clarify what you mean by "..a duplex to pdf..", in normal language not in technical jargon.
A PDF is not a real, physical document. It is a digital document on a computer or a webpage created in PDF format.
A Duplex document is a real document, printed on both sides of each sheet of paper.
If you are trying to scan a multiple page Duplex Document using the Sheet Feeder of your scanner, the ink on the reverse side may be getting caught up in, affecting and/or staining one of the rollers in the Sheet Feeder.
The bottom roller in most non-industrial Scanner Sheet Feeders expects to touch only the plain reverse side of a sheet of paper as it is passed through and turned over to rest on the Platten (scanning surface) of the scanner ready to be scanned.
Multifunction printers with built in scanners and sheet feeders and duplex printing capability are designed in a way that makes them more forgiving of dealing with duplex printed paper.
Duplex printing printed in a laser printer is less likely to cause a problem as long as it is allowed to dry thoroughly. Inkjet printing that is allowed to drry thoroughly should also be okay.
If the scanning is being attempted very soon after printing, then the wetness of the printing may be the problem.
Sheet Feeders that handle duplex printed sheets invariably become stained and need periodic cleaning.
If the document is not too long, you may have to scan it manually, page-by-page.
If the document exists as a PDF somewhere on your computer or on the internet, then it is unclear why you would need to scan it. This is why your question is puzzling.
Post a further comment, if this answer does not help you solve the problem.
I hope this helps.
Aug 25, 2011 | Fujitsu fi-5750C Flatbed Scanner
I can get the Lexmark Pinnacle Pro901 to scan a single page using the sheet feeder but it will not scan multiple pages. The first page completes successfully with a a 'Scanning Canceled' message....
Since Mac Lion OS has just been released, your scan issue might need further troubleshooting. Please contact Lexmark Technical Support Center for assistance.
Aug 09, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Brother MFC-5440CN All-In-One InkJet Printer Logo
116 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
