Double image comming
When i am printing and copying only colours all letters are showing tripple imageing.black copies are ok and fine only for the colours. please give a gud solution .
  • Office Equip... Master
  • 2,899 Answers
Depending on your printer, you may have the option to "align the heads". That should fix it.
Posted on May 06, 2014
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Apr 04, 2009 | HP Color LaserJet 2600n Printer
The colour cartridge won't print
OK, 1st check your color ink either is installed, empty or else. Check it by open your printer cover and see the color cartridge. If everything is fine then maybe is the printer setting. To check this, goto Printing Preferences>Quality/Copies tab, there is an option "Print Color images In Black and White", make sure this option is OFF.
YBC (/\)
Dec 06, 2008 | Lexmark X2500 All-In-One Printer
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
Double ptinting
try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Aug 27, 2008 | Canon NP 7130 Black and White Copier
Printer not printing all colours
try to uninstall the driver and istall it again the reboot the system and make a test page or try the alignemet cartridge software
if this is not helping u tell me so i can help u further
please rate this post.
thanx
Aug 23, 2008 | Office Equipment & Supplies
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Colour problem with printer
After you scan it, do you immediately print it in an image format or do you use word? If you use word i might have a tip that might help.
Before printing, click File>print>click on "Properties" and check that the grayscale printing box isn't marked, if it is unmark it and it'll print in colour.
Also anything is that, when you're scanning. After previewing your scanned piece, double check the mode, either magazine (which is in colour), Black and white or outline (i think)
That's all i have for now.
Sep 09, 2006 | Canon PIXMA MP130 All-In-One InkJet...
24 people viewed this question
k24674
jasbo
jasbo
