Question about Garden
John deere la140
I need to know why I have to keep replacing the steering gear and steering sector every year along with the bushings?
  • 39 Answers
I'm only speculating but keep a eye on front tyer preshers I know low preshers in the front adds a lot of presher to the steering assembely. Most people don't every check there tyres.
Posted on May 06, 2014
Testimonial: "I'm pretty much the same when it comes to my mower as my car. I always check the tires before I drive it."
  • Garden Master
  • 2,478 Answers
Try a little grase. May help. That's the problem with these gensis JD
  • Bill Gabbard
    Bill Gabbard May 07, 2014
    There seem to be plenty of grease on the sector and steering gear. I just took both off the mower this afternoon and both are worn. Going once again to JD Equip to get parts again. Wondering why the bushings that I'm getting once again are plastic and not made of a metallic material.
  • Dennis Key
    Dennis Key May 07, 2014
    Need to seach for metal. May go to Goggle find bushing.
  • 203 Answers
SOURCE: I have a John Deere LA140 Automatic riding lawn
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
That should help. It's on the John Deere website.
Posted on Nov 19, 2009
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: what year is this tractor? L02355G631940 John deere
The first 2355 was sold in 1987.
They were manufactured from 1987 to 1992. With a BHP of 55.4 Hp
The serial number you gave ...is that an ESN or TSN?
You can contact John Deere here and ask them the date yours was made.
https://secured.deere.com/en_US/ag/httpscontent/contactus/index.html
Posted on Mar 01, 2010
  • 6468 Answers
SOURCE: My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Posted on Apr 13, 2012
John Deere LA140 wiring diagram
Request the wiring diagram directly from John Deere.
Jul 28, 2016 | John Deere Garden
Steering is loose and slips on my John Deere LA140 is it hard to fix
The steering gears are striping out. There are two gears that mesh to steer unit.
May 06, 2014 | Garden
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need wiring schematic john deere LA140
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
John Deere Model 140 Hydrostatic Tractor Complete Workshop Service Repair...
Aug 06, 2011 | John Deere Garden
Steering not good. are gear parts available for this old mower?
Yes the steering parts are still available from John Deere. I had just repaired one myself.
Steering Shaft AM101937
Steering Gear AM36998
Bottom Bushing M47067
Jun 12, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
I have a John Deere LA140 Automatic riding lawn mower. I need the diagram to know how to put on the new belt. Belt path?
Nov 15, 2009 | Briggs & Stratton Garden
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
