Question about Canon Laser Class 730i Copier/fax/print/scan Fully Tested Low Meter Only 10,880
Why canon laser class 730i not printing
Printer says it is ready on printer but computer says offline after printing attempt. after reboot it says printer is online, after printing attempt it says it is offline. I know that the network is ok and printer worked before it was moved and plugged back in. installing printer driver seems to release the previous test document to print. then it is offline and will not print as far as the computer is concerned.
SOURCE: we buy canon copier ir3035
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Posted on Jul 29, 2008
  • 916 Answers
SOURCE: Canon Laser Class 7000 Fax won't print
Error code ## 322 indicates that the Fuser not heating (Usually cause by a Bad Fuser Module)
Posted on Mar 03, 2009
  • 88 Answers
SOURCE: how do you print a page count page for a canon
Information about this model Canon Fax:
http://www.usa.canon.com/opd/controller?act=OPDSupportDetailAct&fcategoryid=2283&modelid=15989
There is no manual to download, but if you register your particular fax machine, it may become available. If not, I'd suggest contacting Canon support in your region/country.
Posted on Aug 05, 2009
iservice
  • 318 Answers
SOURCE: how do you print an activity report from a canon
Press the funcktion button then the report button activity report will be displayed press set.
Posted on Dec 06, 2009
SOURCE: How to print FAX transaction report on Canon LC 9500
First you have to lift the panels under the speed dial numbers to expose all of the additional features and setting buttons, Press the REPORT button, then the SET button. This will give you a daily log.
Posted on Aug 03, 2010
Testimonial: "Thanks, that did it!"
Need printer driver for Canon Laser Class 730i
Driver for this unit can be downloaded from this link, just click HERE.
Jun 02, 2011 | Canon 730i Laser Printer
Where can i purchase fuser rollers for cannon model 7301
I assume you are talking about the canon 730i not 7301 but all the same www.precisionroller.com is a decent site for most printer supplies. Here is a direct link http://www.precisionroller.com/fuser-assemblies---units-for-canon-laser-class-730i/products.html
Apr 27, 2010 | Canon 730i Laser Printer
I am using a Canon Image class MF6500 and first I cannot find the driver in the list of downloadable drivers presented and secondly when I go to print a document I get your printer is offline.
to remove the printer from offline right click on it and choose online. and use this link for driver http://canon.driversdown.com/Canon-driver-list/s_119_1.shtml
Oct 14, 2009 | Canon imageCLASS® MF6550 All-In-One Laser...
Canon Laser Class 730i Printer/Fax -- Error Code/Alarm E004. How do I clear it?
E004 Fixing Unit Failure.
I would recomend calling repair Tech to resolve this issue....unless you know how to access service mode and perform a Printer Reset operation. Could be complete Fuser Unit failure.
Jun 02, 2009 | Canon 730i Laser Printer
Canon laser class 730i memory full
Reset the memory
Under the one touch key pad
hit the: Reg Data
hit # key
scroll on key pad until you come to all mem clear #12 and hit enter
Feb 01, 2008 | Canon 730i Laser Printer
Canon Laser Class 730i Copier/fax/print/scan Fully Tested Low Meter Only 10,880 Logo
24 people viewed this question
old marine
old marine
