Question about Mantis 2-Cycle Tiller
Which way to toggle for start?
Someone lent me Mantis 2 cycle tiller (had one a while back and loved it). Problem is which way to toggle for on. Do I place on the circle or the small line of the start switch?
  • Brandon
    Brandon Jun 06, 2014
    Toggle switch should be toward the small line in order to start and run the tiller. Think of the O as meaning "off". Hope this helps!
boscia
  • 163 Answers
SOURCE: Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
SOURCE: Cord is frozen and tiller won't start
take pull rope cover off and oil the clutch that screws on the crank shaft
Posted on Apr 24, 2009
  • 45 Answers
SOURCE: 2 cycle mantis tiller leaks gas thru the carb. -
if it leaks gas,it can **** air.you have to find out whats leaking and stop it.
Posted on Apr 29, 2009
wolfwizard11
  • 5 Answers
SOURCE: Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Posted on Aug 04, 2009
  • 17 Answers
SOURCE: Mantis tiller will not start.
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
Posted on May 24, 2011
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Mantis tiller 7222e
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
Jul 09, 2014 | Mantis 2-Cycle Tiller
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
No color on the carb adjustment screws?
look for H and L cast on carb. body near screws
May 22, 2012 | Mantis 2-Cycle Tiller
When started will not throttle or dies afetr a minute of running
i love the manits tiller they are very strong and dependable.....they are the same as an echo tc210 i parts will interchange.
your issue is more than likely a plugged fuel syetem, flush the fuel tank, replace the tygothane fuel lines with echo 90014 fuel line, and tank grommet, clean and rebuild the carburetor, install a new tank vent for good measure....untill should spring back to life.....hope this helps and good luck ;)
Nov 24, 2009 | Mantis 2-Cycle Tiller
My Mantis will run but I can't get it to "wrap up". It is a 2 cycle gas and about 6 years old. I have rebuilt the carburetor. It's just doggy and won't go into high speed. I have messed with the high speed...
If your Mantis has a ZAMA carb, replace it. Don't bother with a carb rebuild kit.
I had exactly the same problem, did everything you did. New carb fixed it. Runs like new now.
Sep 17, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I had my 2 cycle tiller at a shop and he told me
Mantis Product Owners Information
spacer.gif arrow_red.gif Submit your Question spacer.gif Please Select a Category Below arrow_green.gif Mantis Tiller/Cultivator Gas Tiller FAQ (12) arrow_green.gif Mantis SprayPartner and SprayMate FAQ (7) arrow_green.gif Mantis Blower/Shredder/Vac Service FAQ (3) arrow_green.gif Mantis ComposT-Twin FAQ (10) arrow_green.gif Mantis Edger FAQ (7) PARTS
If you need parts, or wish to return a product, please call our Customer Service Department at 1.800.366.6268
Hours are Monday through Friday 8:00 AM - 5:30 PM Eastern time.
Jun 07, 2009 | Mantis 2-Cycle Tiller
2 cycle mantis tiller leaks gas thru the carb. - will not start?
Apr 23, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
29 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
