Question about Husqvarna Garden
New husqavarna weedeater head won't spin. This was our second time using it and we had been using it for a couple hours cutting down thick ornimental grass when all of a sudden the head stopped spinning. We can fire up the engine and that sounds fine but the head doesn't spin.
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
SOURCE: The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
Posted on Jul 17, 2009
SOURCE: brand new tanaka weedeater, ran fine for 10 minutes,
Just had the exact same problem there is a washer located in there that needs to come out then turn the bras thingy around #18 in parts diagram then put the washer on the outside to space cutting attachment. Manufacturer is an idiot!! Make sure your clutch didn't burn out in the process.
Posted on Aug 16, 2009
SOURCE: my whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Posted on Mar 01, 2010
Weedeater SST25 head not spinning
At the base of most weedeaters there is a mounting point where the coil that extends down and through the shaft to the head is. It "sounds" like over time it may have finally rattled loose. I know on my weedeater, every season I used to take apart the head and take the shaft completely off, tighten things up and then reassemble and I was usually good for the spring/summer. It's amazing at how much vibration those things can generate and that usually spells loose nuts and bolts by the end of the season.
Sep 30, 2013 | Garden
Weedeater head spins off the weedeater body
Jacque It's possible that you are not tightening the head on properly or the nut has completely sheared. If you can get some two part resin glue i would suggest that you try and stick it back with this. I used it on a Mculloch and it lasted years. Make sure to give it 24 hours to set and that everything is clean.
Sep 03, 2013 | Stihl FS 85 Weed Eater
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Acceleration
Re check the valve timing, align the crankshaft and camshaft timing marks, adjust the timing belt and torque the timing belt bolt properly. Hope that works.
May 07, 2013 | 1990 Honda Accord
New husqavarna head wont turn
Will spin or wont spin.? Slight confusion in your question.
May 19, 2012 | Husqvarna 223L
I have a brand new craftmans gas weedwacker. The line went completely in the head (after about ten minutes of use) and I can't get it out. It is a bump type head. Any ideas???
When using the weedeater you cant let the line get too shore otherwise it goes back inside the head, you will now have to pull the bump head apart and reload the snipper cord...
Brad
Aug 01, 2011 | Garden
Hi i have a echo weed eater. It starts with only a couple of pulls and the runs great and sounds great. when i have the head up in the air it spins rather quickly but when i hit grass the head starts to...
check the cable that runs through the shaft from engine to head, it may be brocken or striped but when theres no pressure on the head it spins ok
Jul 24, 2011 | Garden
Our Toro, guaranteed to start, won't start. We can cut awhile, then it will not restart. Plug is fine, getting a spark, and not at all wet, can't seem to find the problem. This doesn't...
I have the same problem. One time this happened and it restarted after a few hours and worked fine for 5 more cuts over a couple of months time. Now again it quit mid cut of my yard and would not restart. When trying to start it would fire for a few seconds and than shut off again. I wated a week to try it again and now it does nto fire at all. This is about a year old mower with only about 10-15 hours of total use.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
Feather lite weedeater disconnected shaft and
You may not have the drive shaft seated all the way into the power head.
You will have to loosen up the drive shaft and push the shaft in but at the same time turning the trim head to fit it into the drive area, then tighten it back down.
Oct 03, 2009 | Poulan Garden
Garden Logo
69 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
