Question about Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl
What does it mean when my cf 50, stops and shows; err 2?
It has been doing it for months and sometimes turning it on and off or unplugging and replugging works but not anymore.
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
Canon error 99
.1. Turn off the camera.
Does the "ERR 99' message appear? If it does, then the camera should be
Does the "ERR 99' message appear? If so, then the CF card is the most
camera body.
If the "ERR 99' message only appears when one particular lens is
If you see the "ERR 99' with a different Canon lens attached, then the
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Cannon 300D EOS Lens 18m- 25m lens, camera showing ERR 99
Error 99 is one of the most annoying ones to get on a Canon SLR as it simply means that an error has occurred which does not fit any other diagnostic code.
There are some error 99 causes which you may be able to diagnose and solve for yourself, but most require that the camera goes to a Canon service specialist. The camera ideally needs servicing and preventative maintenance on an annual basis anyway like all SLR cameras, but few owners other than professional users ever bother.
If your camera is rarely used then you can significantly extend it's life by thoroughly using it through a complete battery charge at least once a month; this will ensure that the internal lubricants are prevented from gumming up. Also give all of your lenses a thorough bit of exercise once a month by mounting them on a camera body, taking a few shots and operating all controls through to their limits. The battery will also maintain its performance characteristics for longer by fully discharging and then recharging the battery at least once a month.
Canon's own official advice (from the photography on the net forum) is as follows; although reference is made to a Canon EOS10D it applies equally you your model:-
"Thank you for contacting Canon product support. I'm sorry to hear that your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced."
In practice, if you still have to send the camera for service you'll almost certainly find that the shutter mechanism needs replacing (usually as it got gummed up due to under usage). Also note that the advice to use a pencil eraser to clean the contacts needs a bit of clarification: do not use a soiled eraser as graphite residues from previous use are conductive and can harm your camera. The eraser doe not have to be new, just rub it on clean paper until the rubber is clean. Also, some folks misguidedly advise using a pen eraser to do the job as it's more abrasive and cleans the contacts quicker. Use of pen erasers is an absolute no-no: the abrasive is usually conductive metal oxide particles, and even when it isn't there is a risk of abrasive particles falling into your precision piece of kit where they get embedded in the lubricants turning them into grinding paste.
I hope that my reply has been of some assistance, all that I ask in return is that you return the favour by rating my answer.
Nov 06, 2009 | Canon Digital Rebel / EOS-300D Digital...
My canon eos rebel xti keeps showing error code 99
following:
steps:
camera body.
Sep 22, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon EOS 400D and when i turn it on it works fine but when i start to use the flash it doesn't flash i get on the screen ERROR 99 ! what do i do ?
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 14, 2009 | Canon Digital Rebel / EOS-300D Digital...
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 99 & err cF in my canon 350d camera
had the same problem before
found this guide online
camera body.
Jan 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My camera say err CF
These are steps to Fix Err 99's, have a go and see if resolves your other problem too.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Dec 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Dometic CF-050DC CF-50 Waeco CoolFreeze Portable Fridge Freezer DC Onl Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
