Question about Fuji FinePix S7000 Digital Camera
Fuji s7000 My fuji camera 's view finder is displays images in red/pink . Tried resseting the camrea and nothing works. Is my ccd sensor bad ?
  • 3 Answers
Re: fuji s7000
If you are using rechargeable Ni-MH batteries discharge fully using the camera facility. Recharge and then discharge again. Recharge and hopefully the problem will be resolved.
Good luck
Posted on Nov 16, 2007
0 characters
3 Points
My FUJI S7000, Treasured present from wife has failed.view finder and LCD are blank, all other functions ok.Also playback & downloaded shots produce a black image, behaves like a SLR whose whos shutter...
looks like you have a dead ccd, reset your camera , if this does not help bang hard with back of your to the base of your camera, last resort take to service for change of ccd
Mar 04, 2015 | Fuji FinePix S7000 Digital Camera
Turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Jul 25, 2010 | Fuji FinePix S7000 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Power on to take picture, but view finder is dark, and snapping a picture, provides a black picture.
Probably the CCD is dead. It's a well known problem with S7000. It's a hardware problem, the CCD has to be changed. For S7000 it usually comes with the lens and it makes the repair quite expensive. It's about 250-300$ here. You should contact your local Fujifilm service center.
I work in a camera service center authorized by Fujifilm.
Sorry for the bad news!
Aug 01, 2009 | Fuji FinePix S7000 Digital Camera
Photos are turning out pink and green from my powershot A85
Its is bad ccd imager known problem in Canon A85 camera.
Canon will repair A85 free of cost in ccd imager problem.
Click Canon CCD Imager Advisory for details.
Apr 22, 2009 | Canon PowerShot A85 Digital Camera
Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
pls rate me FIXYA for this if u like
Dec 31, 2008 | Fuji FinePix S7000 Digital Camera
Fiji finepix s7000
Hi. From past experience I would say that these symptoms suggest the early stages of CCD failure. It usually starts with lines etc as you describe and progresses into wavy, blurry pictures or partial pictures and eventually the ccd just goes black. If it is CCD failure, the camera will usually still work when viewing pics that are already on the card.
Jul 02, 2008 | Fuji FinePix S7000 Digital Camera
Fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Mar 23, 2008 | Fuji FinePix S5000 Digital Camera
Cloudy white pictures
Cloudy images are usually a result of ccd gone bad. Try power reset, maybe it helps..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
280 people viewed this question
Top Fuji Digital Cameras Experts
Steven Wander
Steven Wander
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
