My technics model sa r 277 stoped playing sounds but if you get really close to it you can hear the beat of the music really really low its like theres no power to push the sound what can i do
SOURCE: technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Posted on Aug 05, 2008
marsrover
  • 682 Answers
SOURCE: Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Posted on Aug 06, 2008
  • 22 Answers
SOURCE: technics sa-ax730 won't play a&b speakers at same time.
Low imp probably means "Low Impedance". You've got either too many speakers hooked up in parallel on the same binding posts or spring contacts or the single sets of speakers on A & B are low impedance to begin with (i.e. 4ohms).
When you switch between A, B, and A + B, the last setting just puts B in parallel anyway.
Too low an impedance means higher current and the receiver may not be capable of handling it. Check your owner's manual for recommended speaker impedances.
If you test with a single set of speakers, switching the actual cables from A to B should work (even at a nominal 4ohms). If that's the case then you will need a different set or sets or speakers to hook up to B. If it doesn't work at all and still says "low imp", test with a known higher impedance speaker (i.e. ~8ohms).
If none of that works, you're on your own.
Good luck in any case.
Posted on Feb 04, 2009
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
My technics model sa r277 stopped playing music .when I turn it on you could hear the beat coming from inside the receiver but really really low you have to literly put your ear on the receiver to hear it...
fan usually kicks on at high temperatures so being your not using any increased wattage (incurring heat and excessive voltage) there's no need to run the fan... (like sitting in your car listening to the radio...without the car running or being on...no gas only electrisity being used, so engine isn't running thus no heat or need for cooling system to be on! ie: water pump, radiator & fan etc.) you could have just very well blown a fuse, but typically you would here your amp 'clip-out'...indicating overheating problem...check fuse, in not the problem (first verifying fuse is still good, 'continuity'...go to manufacture's website an see if you can download a "SERVICE MANUAL"?! this will give you more insite, troubleshooting tips and technical specifications &/or updates...good luck!
May 08, 2014 | Audio Players & Recorders
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
I am playing Cd's and have a pair of Definitive Technology- Model BP-10 tower speakers connected to my Technics SA-DX1040 5.1 Channels Receiver and while the music is playing, all of a sudden the music...
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Dec 27, 2010 | Technics SA-DX1040 Receiver
The speakers on the left side of my technics stereo have stopped working and are making a loud humming sound while the speakers on the right side still play music normally model number is sa-120 and the...
Check the input cables from the source you are playing at both ends. Sounds like an input problem, not a speaker problem. Twist the RCA connectors as you push them in to make sure the connection is good.
Aug 29, 2010 | Audio Players & Recorders
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Interface SA-DX940 with Sony Vega TV and Magnavox Video Recorder
you need an upscaler for the vision sound will be dolby stereo 2
Dec 08, 2008 | Technics SA-DX940
My computers sound not working.
try new sound drivers for your model pc ok
Feb 07, 2008 | Dell A215 Computer Speakers
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
37 people viewed this question
 Grubhead
Grubhead
