Technics model sa r 277 will not play any sound help
marsrover
  • 682 Answers
SOURCE: Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Posted on Aug 06, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
SOURCE: i need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Posted on Feb 01, 2010
Grubhead
  • 5126 Answers
SOURCE: on switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Posted on Mar 09, 2010
No sound from left channel on my Technics SA-R 230
May just be bad connections on the speaker relay. Flip the main board over, and check those connections. It is pretty common on these older models.
Jan 18, 2013 | Technics Audio Players & Recorders
I am playing Cd's and have a pair of Definitive Technology- Model BP-10 tower speakers connected to my Technics SA-DX1040 5.1 Channels Receiver and while the music is playing, all of a sudden the music...
There are 2 major possibilities and since you didn't say if the sound comes back here's the general split.
1. The power amp section could be having problems and/or protection circuits are kicking in. In this case repair of the amp will be needed.
2. There is a bad connection somewhere making the audio path go bad. In this case a good can of contact cleaner applied to all switches and controls may help. If not, the bad connection may be internal. If tapping (or rapping) on the unit makes it come back, there's probably a bad internal connection.
If letting the unit cool down brings back the sound, its the power amp section.
Dec 27, 2010 | Technics SA-DX1040 Receiver
Technics sa-gx670 reciever sound drop
it could be that your amp chips are gettin hot
Jul 22, 2010 | Technics SA-DX750 Receiver
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Output Power of a Technics SA-DV250 sound system.
100 watts per channel both channels driven into 6ohm. You can download the owners manual at http://www2.panasonic.com/consumer-electronics/support/ (Technics and Panasonic are both made by the same company) Then enter your model #. the specs are on page 23 of the manual.
Feb 25, 2009 | Technics SC-DV290 System
Interface SA-DX940 with Sony Vega TV and Magnavox Video Recorder
you need an upscaler for the vision sound will be dolby stereo 2
Dec 08, 2008 | Technics SA-DX940
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
Aug 08, 2007 | Technics SA-DA10 Receiver
29 people viewed this question
 Grubhead
Grubhead
