Question about Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB
Is it possible to find front plate/votute for DJAYGB-3162 if not what pump replaces this model & do you have it?
    New Friend:
    New Friend:
  • 45 Answers
Yes the Volute can be found here:
http://www.oskopoolnspa.com/Pool-Spa_Uncategorized/Pump_Body_17303-0001
Hope this helps,
Dan Osko
Osko Pool n Spa
Posted on May 16, 2014
2 Suggested Answers
  • 8404 Answers
SOURCE: Great Lakes Spa pump. Any way to diagnose outside
If I understand your question, your spa pump will not spin up.
I believe your start capacitor has failed. Remove the back from the motor, you will see the black capacitor on the left hand side. There are several wires coming out of the capacitor. Somewhere on the body is a number. Get a preplacement from a FixYa.com advertiser, your community pool supply company or at www.repairclinic.com
Be careful as you service this electric storage device. Also, make sure you wire the new one exactly like the old one.
I believe this minor service operation will get your pump rolling again.
Thank you for posting at FixYa.com
Please vote
a
Posted on Nov 10, 2009
Drainage plug for Sta-rite djaygb pump is broken
there is two of these plugs on your pump, remove the other plug and head down to ace hardware.. remember easy on the thread tape
jay
Nov 17, 2012 | Sta Rite Pool & Spa
DeWalt D55170 oil pumping ,scored cyls. Can a hone & ring replacement cure it?
It is possible to hone the cylinders and replace the rings to save the pump but don't remove too much metal as there are no oversized rings available for this type of piston/cylinder set. Also make sure to find out what caused the scoring in the first place and remedy that or you'll be replacing the cylinders and pistons next time.
Feb 12, 2012 | Air Tools & Compressors
My MAYTAG washer 9000 series with steam is flashing F21 and won't drain?
F 21 means slow drain if you can here the pump that means something pluging it. remove lower kick plate . the pump will be there remove cleanout counter clockwise turn .put back together.. hope this helps...good luck
Feb 01, 2011 | Whirlpool AWM9000 Front Load Washer
How do you find and replace the windshield washer pump on the 2005 dodge magnum RT
The pump is located inside of the fluid holding tank itself. I would suggest checking the 30 amp (pink) fuse for the windshield washer pump before attempting to replace the pump. The fuse is located in engine compartment distribution block. Find the location of the 30 amp fuse by looking in your car's manual. If the fuse looks fine try swapping it out with an identical 30 amp fuse from the distribution block and trying the washers again. I believe there is one other 30 amp fuse (possibly for the headlights?) in that same location.
Replacement (if necessary) is no easy task as it would require removing quite a few parts of the front fascia of the vehicle including the front bumper and possibly passenger's side fender.
Dec 10, 2010 | 2005 Dodge Magnum
When i switch on the machine ,the monitor displays monitor is in power save mode
Click start- open control panel then open power option then disable power saving mode from threre.
I hope that this has been very helpful for you
Nov 27, 2009 | Sun Microsystems Ultra 5 Power Supply (p/n...
Please vote
a
Nov 10, 2009 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
I dont no where the filter is back ,front or some where else
Two possibles on this model. Either behind the kick plate at front or in the pipe running from pump to drum at the drum end. Access this by taking the plate off at rear.
Thankyou for using Fixya.
Feb 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Maytag PAVT454EWW pump 21002240
Don't worry about it, you can install the new pump with out the plate. It will work just fine. They must of redesigned it. I get them this way all the time, Catriver
Sep 22, 2008 | Maytag Performa PAV2200
Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB Logo
159 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
