Question about Saeco Coffee Makers & Espresso Machines
How do i get rid of the display - purging
When I start the unit I get the purging display and I cant get to close
  • Dr Eli Hakim
    Dr Eli Hakim May 10, 2014
    The machine is a Saeco Automatic Model SUP 022
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 48 Answers
Tell us for what model you are tallking about .
Posted on May 10, 2014
How do I get rid of error code 6C10
Error says that either something is jammed in the purge assembly, the unit on the right that cleans the print-head, or the purge assembly is stuck or broken. If you unplug the printer with the carriage in the center you can use a flashlight to inspect the area on the far right where the print-head parks.
May 05, 2011 | Canon Office Equipment & Supplies
I got a 1996 ford thunderbird 6 cly and the problem is a p1443 i need to know what i do to fix this or even if it is worth fixing and a est about how much it would cost thank you
CODE P1443 - LOW PURGE FLOW OR NO PURGE FLOW CONDITION DETECTED.POSSIBLE CAUSES EVAP CANISTER PURGE VALVE STUCK CLOSED MECHANICALLY FUEL VAPOR HOSE BLOCKED BETWEEN EVAP PURGE VALVE AND THE FTP SENSOR OR BLOCKED BETWEEN PURGE VALVE AND INTAKE MANIFOLD OR VACUUM HOSE BLOCKED BETWEEN PURGE VALVE AND INTAKE MANIFOLD.CANT GIVE PRICE CHECK UNTIL FIND OUT THE PROBLEM.
May 04, 2011 | 1996 Ford Thunderbird LX
Printer makes loud noises while powering on, and displays error code 5C00
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
Nov 23, 2010 | Canon PIXMA MP510 All-In-One InkJet...
CANT GET RID OF 'UNABLE TO CLEAN MESSAGE' DISPLAYED ON DCP-120 PRINTER
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then'menu' one by one...
2. Press the arrow up or down to go to'maintenance 80'.
3. Press 'mono start' several times to go to'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered thiscombination, the purge numeric value will be reseted to 00000.
Oct 26, 2009 | Brother DCP-120C All-In-One InkJet Printer
Alarm light is flashing, data says check printer, press resume. ##345 comes up also.
##345 is jammed cartridge error.
Look for any obstruction or foreign matter in the area of the purge unit.
If this not help you may have a problem in purge unit.In this unit there is an axis which broke.You need to replace the Purge Unit.
Oct 12, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Error Code 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Apr 26, 2009 | Canon MP830 All-In-One Printer
How to get rid of 6A00 on printer and error code 5C10 on computor
Hi
Ok try this
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Hi
Good luck
Solution 1:
Solution 2:
Solution 3:
Mar 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP530 alarm and 6A00 error
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Coffee Makers & Espresso Machines Logo
147 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
