Question about Car Audio & Video
1998 saturn sl igntion wiring daigram - Car Audio & Video
motor1258
  • 6674 Answers
SOURCE: Cam Shaft Position Sensor 1998 Saturn SL
Have a look at this link, scroll to your engine & click on picture to expand for better view.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528017e904
Posted on Jan 23, 2009
  • 186 Answers
SOURCE: solution for 1998 saturn sl
Hello DTC P0341 & P0133 very common saturn Codes.You need to check condition of Plugs & wires,If not New Replace All Plugs & Wires,also I would replace the #1#4 Coil for the P0341.For the P0133 Reaplce your front O2 sensor with an OEM sensor,not an aftermarket.
Posted on May 11, 2009
  • 299 Answers
SOURCE: replace spark plug wires 1996 saturn sl series
engine side 1234/coil side 4123,all left to right.
Posted on Jun 17, 2009
  • 3911 Answers
SOURCE: fuse box diagram for 1998 saturn sl
There is an interior fuse panel just to the left of the passenger's left knee. The cover It is held on by velcro. After you take off the cover, you will see a diagram on the inside of the cover telling you which fuse is for what. This is covered in your manual, which is in the glovebox. If you do not have a manual you can get one off ebay for a few bucks.
Posted on Jul 26, 2010
airjer995
  • 5332 Answers
SOURCE: 1998 saturn rear suspension diagram
http://www.gmpartsdepartment.com/parts/1998/SATURN/SL%20SERIES/?siteid=214533&vehicleid=1317293&diagram=IB96580
Posted on Jan 21, 2012
Testimonial: "didnt know what the part was called diagram i/d the broken piece I. can order part thanks much Earle."
My 1998 saturn SL shakes in the front where my wheels are when i go at least 50 mph
FRONT TYRES WRONG PRESSURE WHEELS NEED BALANCING POSSIBLY
Apr 01, 2012 | 1998 Saturn SL
Jan 21, 2012 | 1998 Saturn SL
What is the firing oder of a 1998 saturn sl
Check this diagram for 1998 Saturn SL 1.9 liter DOHC VIN "8"...
Hope helps (remember to rate and comment this answer).
Sep 06, 2011 | 1998 Saturn SL
What is the correct order to plug the spark plugs wires to the coil pack?, cilynders are 1,2,3,4 from passenger side to driver side and coils pack is form by two "modules"
1998 Saturn SL
1.9 liter DOHC FIRING ORDER is: 1-3-4-2
http://autorepair.about.com/library/firing_orders/bl-saturn-firing-98.htm
There are several engines on this car - so check your vin number and go to the link above for more help
RICESKI
Mar 20, 2010 | 1998 Saturn SL
I need location of the fuel pump on a 1995 saturn
the fuel pump is located inside the gas tank. You have to lower the gas tank, unlock the ring that holds it in, unhook the wires and fuel lines, and then you can lift it out.
Nov 29, 2009 | 1998 Saturn SL
Solution for 1998 saturn sl
May 03, 2009 | 1998 Saturn SL
1998 Saturn SL not sparking and not starting
onepx.gif 1. Test the AC voltage output from the Crankshaft Position (CKP) sensor while cranking at a normal speed. It should produce at least 250 millivolts.
2. Retest the voltage at the Powertrain Control Module (PCM) on the Yellow wire in terminal D13 and the Purple wire in terminal D14.
let me know please thanx i hope it fix
Mar 17, 2009 | 1998 Saturn SL
Is my 1998 saturn sl wired for rear speakers
It should be, look in the trunk, behind the back seat
Mar 01, 2009 | 1998 Saturn SL
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
