Our church has a Sony CCP 13nn (master) and 14nn (slave) cassette -to - cassette duplicator devices. Is there a way to connect the master device to a computer for MP3 file creation? The output cable is a round 9? Pin connector. Any assistance is greatly appreciated!
  •  Mike M
    Mike M May 07, 2014
    I can't find your product anywhere on the net. If the 9 pin connector is a DIN style plug there is probably little chance of doing what you want. Please check the model #.
  •  Mike M
    Mike M May 07, 2014
    OK found it Model is CPP 1300. The 9 pin DIN jack is for connecting the next of a possible 23 Copying decks to the master.
  • 3,320 Answers
Tapes are analog, MP3's are digital. There is no way for an analog device to create a digital file.
Posted on May 07, 2014
4 Suggested Answers
Decoder1
SOURCE: NHDE35 Enclosure
Posted by Decoder1 on Feb 25, 2009 I also had a problem with XP not recognizing the hard drive. The USB Mass Storage Device was reporting a Code 10 (Device cannot start). Ryockey provided the solution in that the drive pins can be offset by one set when connected to the interface. Be careful to get the pins aligned correctly, it worked for me. I also have my drive jumper set for Master. Thanks Robert!
Randy P.S. I am using a Seagate 250 GB HD 7200.7 Ultra ATA
Posted on Feb 25, 2009
preachw996
  • 1179 Answers
SOURCE: pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
Posted on May 23, 2009
themg
  • 6 Answers
SOURCE: NEXXTECH NX2
If this is a new drive, you will need to format it before it will show up in My Computer. To do so, start by right-clicking on My Computer, then choose Manage from the menu. Click on Disk Management, you should see a list of drives in your system. Your new drive will show up as unallocated space, right-click on that and choose New Partition, choose the size of the partition you want, and choose to format it. Once the partitioning and format process is complete, the drive should show up in My Computer under a new drive letter.
Posted on Jun 12, 2009
Sony CCP-1300 Cassette Duplicator's heads not moving up when pressing copy or auto copy.
Get the service manual and then look into power supply section first then the control section.
Jun 04, 2014 | Sony Audio Players & Recorders
Tip
Bluetooth Basics ? How it works
Network Topology
Any Bluetooth device can be a master or a slave, depending on the application scenario.
Bluetooth employs frequency hopping spread spectrum (FHSS) to communicate. So in order
for multiple Bluetooth devices to communicate, they must all synchronize to the same
hopping sequence. The master sets the hopping sequence, and the slaves synchronize to the
Master.
A piconet is formed by a master and up to seven active slaves. The slaves in a piconet only
communicate with the master.
A scatter net can be formed by linking two or more piconets. When a device is present in
more than one piconet, it must time-share and synchronize to the master of the piconet with
which it is currently communicating.
While the topology and hierarchical structure of WLAN networks are relatively simple,
Bluetooth networks are far more diverse and dynamic. They are constantly being formed,
modified, and dissolved, as Bluetooth devices move in and out of range of one another. And
because different Bluetooth devices can represent many different usage profiles, there are
many different ways in which Bluetooth devices can interact.
Service Discovery
The concept of service discovery is utilized to determine what kind of Bluetooth devices are
present and what services they desire or offer. When a Bluetooth device requires a service, it
begins a discovery process by sending out a query for other Bluetooth devices and the
information needed to establish a connection with them. Once other Bluetooth devices are
found and communication is established, the Service Discovery Protocol (SDP) is utilized to
determine what services are supported and what kinds of connections should be made.
In order for the above to happen, devices willing to connect must be located. Some devices
may be set up so that they are invisible. In this case, they can scan for other Bluetooth
devices, but will not respond if they are likewise queried. Applications determine whether a
device is connectable or discoverable, and thus applications determine the topologies of
networks and their internal hierarchies.
on Dec 10, 2009 | Electronics - Others
120v transformer in sony ccp 1300 broken
The thermal fuse is most likely to have failed and that may not necessarily be terminal. A Sony agent is bound by agreement to replace the transformer.
Nov 05, 2013 | Sony CCP-1300 Standard Cassette Duplicator...
How to connect it as a slave. there is no guide to follow on hd label
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is
May 20, 2011 | Seagate Cheetah 15K5 Ultra320 SCSI 146GB...
Need to know which is master, slave and cable select
these may vary depending on the make of your hard drive
enable cable select:I:: master or single driveI:::
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 23, 2011 | Computers & Internet
MY COMPUTER KEEP SHOW NEW HARDWARE NOT FOUND
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Primary ide slave no detedted secondary ide slave not detected computer dont start up properly
you need to verify the jumper settings on the devices that are connected through the IDE flat cable.
picture: http://support.euro.dell.com/support/edocs/storage/P120718/drijump01.gif
set the jumpers in such a way, that on one flat cable there is both a master device and a slave device. if you're not sure what to choose as master, you can use the CS (cable select) setting on both devices to let the system board choose which one will be master and which on will be slave.
keep us posted on any evolution if you will...
Jun 22, 2009 | ASUS P5S800-VM Motherboard
Unit Cassette Duplicators Sony
HELLO THERE!
IF YOU HAVE ANY PROBLEM OR NEED PARTS FOR THE CCP-1300 - 2410F.
PLEASE FEEL FREE TO CONTACT ME IN ENGLISH TO:
SIMONGA@SMILE.NET.IL,
THANKS.
SIMON GALIMIDI.
Jul 25, 2008 | Sony CCP1300 Monaural 1-to-3 16x Master...
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
How to reassemble the Wytron 688
have you got one set as master and the outher set as slave ?
Jan 12, 2008 | Wytron Technology Wytron-688 DVD...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
