Question about Peavey Cs 1400 Power Amplifier
Only one channel works on my amp. ?
Is this an expensive job
  • Peavey Master
  • 637 Answers
It depends on brand and size amp... what type of amp. Ask yourself...if it was cheap when you purchased it. It may be cheaper to buy a new one. Please tell me what type and brand. We can go from there.
Posted on Jun 18, 2014
Is it possible to bridge 4 of the channels into 2
Yes it is....you must find out how many ohm stable the 4 channel amp is first. If you "bridge" 4 channels into 2 channels, it will cut the ohm load in half... In other words if you have two 4 ohm subwoofers... And your amp is only 4 ohm stable... And you wire them parallel + to +.... - to - on a dual voice coil sub..... You could fry your amplifier. You can google wire diagrams for the exact equipment you have. It will show you how to "not" fry your nice expensive amps.. Good luck
Oct 26, 2015 | Car Audio & Video
Centre channel pops
Popping is usually a sign that the output transistor on the amp (center channel) has blown - quite expensive to repair. eBay is good for picking up cheap but fully working receivers
Jan 16, 2014 | Kenwood KRF-V5100D
New clutch and pressure plate installed 6 months ago why should it be slipping again
To honest- you know more, than we could even guess at
I would say the job you paid for wasn't done, as I would have done
it, six months ago
Repairs Shops don't always machine the flywheel & never balance
any of the assy & who knows the parts quality
Yes----- I once owned a trans shop, so I have seen some
not so good employees & managers at work & it isn't pretty,
sloppy work & lack of knowledge is my guess at your expense
Mar 05, 2013 | Daewoo Nubira Cars & Trucks
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Mackie 1202. Channel 1 & 2 dead. Bought from ebay. Simple fix?
This could be caused by one or more of numerous issues. Generally speaking, it will most likely be a job for an electronics technician and could become expensive, depending on the root cause. If the seller of the console did not list this problem in the product description in the auction, I would definitely contact them and negotiate a reduction in price after you establish the cost of repair. A shop would be able to give you a "ballpark" idea of the cost (at least a minimum to even look at the console). You also should have the option to return the unit to the seller, unless specified otherwise, for a refund.
Nov 02, 2010 | Mackie 1202vlz3 12 Channel Mixer
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Mar 16, 2009 | Bryston 4B SST 2-Channel Amplifier
Hello, I own a 2003 phillips 46" rear projection HDTV model no. 46PP9302 & serial no.78201545. I went to change the channel and the picture just went out but there is still audio. Could it be the...
try resoldering the vertical output IC thats most likely the problem if not the vertical output IC may need replacing. If you can solder you may be able to do this yourself as its not a hard repair the replace the output IC
Apr 18, 2008 | Televison & Video
Channel not working
Get it repaired by a car audio shop, if its expensive get a new amp.
Apr 13, 2008 | Infinity Reference 7541a Car Audio...
Peavey Cs 1400 Power Amplifier Logo
44 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
