Question about GE Refrigerators
My fridge is beeping, too
My GE fridge PTS25LBMARBB will change its settings to 0 (turn itself off) if I don't lock the settings. When the settings are locked, it will do three beeps in a row, pause, do it again, and again for half an hour or so. The door is sagging a bit so I built up the point that makes contact to signal door closure with 1-4 pennies. That didn't make any difference. Do I need to replace the temp control board, the mother board, or both?
    Novelist:
  • 150 Answers
You are most likely experiencing a stuck key issue on the touch pad, the unit is signaling you with 3 beeps telling you there is a stuck key. Part# WR04X10097 approx $183.65. Pleazer Appliance...
Posted on May 07, 2014
tzweeb
  • 318 Answers
SOURCE: Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Posted on Dec 28, 2008
tborn6
  • 700 Answers
SOURCE: beeping
basically its telling you that it's not maintaining the temperature that you have it set for. if indeed you do have this particular model number contact me and i have the service manual for it.
Posted on Feb 04, 2009
  • 93 Answers
SOURCE: kenmore ref. water dispenser lock turns on itself & beeps
Behind the dispenser housing in the door is a small control board. It is messed up....could be from water getting on it or a voltage spike during a storm....but that is what controls your dispenser.
Posted on Sep 12, 2009
  • 82 Answers
SOURCE: kenmore refrigerator control box temp. keeps changing by itself
Your most likely cause is the $170 control board. It is the only thing that I know of that can change the temperature automatically. Please rate this post.
Posted on Dec 14, 2009
Testimonial: "Thank you, even though it wasn't what I wanted to hear, at least I can move forward now without second guessing myself."
heatman101
  • 43501 Answers
SOURCE: The fridge keeps beeping. Door is closed.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 22, 2010
Left door of F/P fridge part for a week. Now red light is flashing, beep stopped but fridge not cold enough.
Hello Jennifer;
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
Jan 01, 2015 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
The control lock keeps on beeping we did the 5 sec hold and it still dont go off
What is the model of your fridge. Also you can try the other button and check if they repsonce and if any one does not react when it pressed.
Nov 26, 2010 | GE Monogram Side by Side Refrigerator
Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Feb 11, 2010 | GE Refrigerators
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Temperature control panel beeping
There are 3 models with this model #,so not sure if your has lock.
If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
This feature allows you to lock the controls
so the settings cannot be changed.
To lock the controls:
Set the controls to the desired settings.
Press and hold the lock pad for
3 seconds.
When the controls are locked, the indicator
light will come on and the control settings
will not be displayed.
To unlock the controls:
Press and hold the lock pad for 3 seconds.
After unlocking the controls, the settings
will be displayed, the lock indicator light
will go out and the settings can be changed.
Apr 14, 2009 | GE PTS22LBN Top Freezer Refrigerator
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
