Question about Vacuums
Dyson DC44 Animal Vacuums.
I need to hold the power button to use this vacuums. Is there any way to change it like toggle mode. Thanks, Kevin
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
There's a short in power cord.
Posted on May 06, 2014
SOURCE: dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Posted on Nov 15, 2008
  • 389 Answers
SOURCE: Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Posted on Apr 09, 2009
Samyfam
  • 378 Answers
SOURCE: dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Nov 07, 2009
Testimonial: "thanks so much for taking the time to reply...sounds like we need a replacement!!!...will get the dyson ball this time..hope it's good! thanks again!"
  • 4 Answers
SOURCE: Power shuts off on my dyson dc17 animal
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....
Posted on Jan 04, 2010
VacuumRepair
  • 438 Answers
SOURCE: No power to Dyson Animal
Hi There,
I'm almost 100% positive that the cord on your Dyson DC07 Animal has shorted out and needs to be replaced. Usually what causes this spark, and cord failure is when the cord is pulled out of the wall to hard. I have to admit that I'm guilty of doing this same thing. If I'm on the other side of the room from the plug, and I need to change plugs, I have been known to try and swing the cord out of the plug, and I have myself burned through a cord or two. The spark is usually caused when the wires inside of the plug touch each other, or short circuit.
No worries, this is not an expensive, or difficult repair to do. Here's what you'll need in order to complete this repair:
- T15 Torx Bit Screw Driver
- Dyson DC07 Power Cord For All DC07 Models, Part 905449.
- A 2mm or Smaller Flat Head Screwdriver (width of the tip)
- Needle Nose Pliers
- Patience (haha)
IMPORTANT: MAKE SURE YOUR VACUUM IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay the vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles. Also be careful when removing these terminals, don't force it or it will break the pole right off of the switch, and you'll then have to replace the switch along with the cord. Also you'll need to remove the two white wires that are connected together apart, also using your needle nose plyers.
Step 5. After you've removed the two terminals connected to the switch, as well as the two white wires that were connected, follow the electrical cord up until the point that it enters the vacuum cleaner to the rubber cord protector. Lift straight up on this cord protecter to remove it from the vacuum.
Step 6. You'll have to now slide the cord out through the cord protector so that you may install the protector on your new cord. Unfortunately as you'll see, your new cord does not come with the plastic terminal protectors that are on the end of the wires, so you'll need to take off these plastic ends on both the black, and the white wires that come from the cord. The other wire that you see in there that has a white wire with no plastic cover, and a black wire that does have the plastic terminal. There's no need to remove the plastic terminal from the wire that runs down into your motor, just leave these alone. If you look closely at these plastic terminal covers, you'll see that one side of them have two little ridges on the inside, also that the bottom is flat, and the top rises upwards on one end. To remove these plastic parts, use your 2mm flat head screwdriver and insert it through the top part that has the two ridges on the indside. While your screw driver is in as far as it will go, lift upwards away from the wire while pulling out the wire at the same time. Repeat this on the other wire as well.
his is how the wires look like without the terminals:
Step 7. After remove the plastic terminal covers from the wires, pull the cord through the rubber cord protector and remove your old cord. Open your new cord, and now you'll have to feed the two wires through the cord protector. Simply push the cord through the ribbed end of the cord protector. You normally can push the cord hard enough so that the ends of the wires will come out the other end fairly easy. If the wires don't come out, use your needle nose plyers to pull the metal ends of the wires through the rubber cord protector.
Step 8. Reconnect the wires to the switch, as well as connecting the two white wires together. Here's how the wiring should look like when done properly:
Step 9. After reconnecting the wires to the switch, and to the other white wire, you'll need to put the switch back in place, along with the cords, and the cord proector. You can see little channels that the cords actually sit in to keep them from pulling out. Place both the wire on the bottom that goes to the motor, as well as the electrical cord into these channels. The two white wires that are connected together go to the left of the switch. Here's how it should look like when you're finished:
Simply put the switch housing cover back over the switch and cords, and screw the Torx bit back in, and then test the vacuum to make sure that the cord works.
I hope that this repair was helpful to you with fixing the cord on your Dyson DC07. If you have any questions about this repair, or need further help on replacing the cord, please use the Clarification Request, or leave a comment on this repair and I'll be more then happy to help you further. If this was helpful to you, please be sure to rate the review helpful by clicking the thumbs up icons in the top right hand corner. Again, if you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thank you,
Chris J.
GoVacuum.com
Posted on Apr 15, 2010
My Dyson DC44 animal has the MAX light on all of the time but it appears empty....any ideas?
ring dyson for support it could be the micro particle filter is blocked up and needs cleaning.
Dyson have really good support
http://www.dyson.com.au/support/dc44/dc44-animal-bu/maintaining-your-dyson-machine/wash-the-filters
Sep 10, 2016 | Dyson DC44 Animal Cordless Vacuum
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Pulsing then stops
Hi there, it's Jack at Dyson.
Dyson Digital Slim cordless vacuums such as DC44 Animal are engineered to make a pulsing noise to warn you if the machine has a blockage. This can occur if an item too large for the machine has been vacuumed up accidentally. It's easily resolved by checking the floor tool, wand and bin inlet: http://www.dyson.co.uk/support/dc44/dc44-animal/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual-dc44/no-resolved-redirect-to-check-the-wand/check-wand
I'm confident following these steps will resolve the issue, but for any further guidance from our experts you can reach us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 06, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Dyson DC44 Animal - after recharging battery, motor won't start?
Do not leave it to recharge overnight! Try recharging it again but just for the time it needs, and then unplug. Then try vacuuming.
This worked for me when I had the same problem.
Jun 28, 2014 | Dyson DC44 Animal Cordless Vacuum
Why won't my Dyson DC44 rechargeable vacuum brush attachment not work or pick up anything?
Hi Kim, it's Jack at Dyson.
If your DC44's motorised cleaner head doesn't seem to be picking up as well as it should be, it sounds as if there is a blockage somewhere. To check for this, please follow the steps shown in our Support guide: http://www.dyson.co.uk/support/dc44/dc44-animal/maintaining-your-dyson-machine/removing-blockages-from-the-power-floor-tool
The video I've attached should also help you check for and remove any threads, hair or debris caught around the brush bar.
If you'd like further help after you've given this a try, please get in touch with us directly so our experts can talk you through some additional troubleshooting checks. You can reach the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1800 239 766 (AU).
Jan 29, 2014 | Dyson DC44 Animal Cordless Vacuum Handheld...
I have a new Dyson DC44. It has a screw rather than a push button to remove the battery. I bought a spare battery. When I unscrew/loosen the screw, the screw won't come out and the battery won't pull
Hi Mike, it's Jack at Dyson.
Our cordless vacuums including DC44 Animal now include a fixed battery which is not designed to be removable in everyday use. As DC44 offers a runtime of up to 20 minutes of high, constant suction, we've found Dyson owners don't usually need an additional battery to complete cleaning tasks.
The battery is removable if it ever needs to be replaced, but we would advise against attempting to swap the batteries in normal use as the machine isn't designed to be used in this way.
For further advice I'd encourage you to contact our Support team directly - you can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Nov 22, 2013 | Dyson DC44 Animal Digital Slim Cordless...
Dyson dc44 motor is intermittent
Hi Ryan, it's Jack at Dyson.
I'm sorry to hear your DC44 Animal seems to be working intermittently. We should be able to help with this but we'll need to take you through some quick troubleshooting checks when you have your machine to hand, to confirm what may be causing this.
You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA). If a replacement part is needed, we'll be able to confirm if this is covered under your machine's 2-year guarantee.
We'll look forward to hearing from you.
Best wishes,
Jack
www.dyson.com
Nov 04, 2013 | Dyson DC44 Animal Cordless Vacuum
DC44 Animal Cordless Vacuum power cuts on and off while trigger is pulled
This doesn't address the intermittent power cut offs...power cuts off intermittently and you have to keep recycling the power 'trigger' to get it to work...total PIA
Dec 17, 2012 | Dyson DC44 Animal Cordless Vacuum
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
