Question about Canon Cameras
I have a T2i. The camera flashes three time, but the shutter never engages. It doesn't work in any mode. It used to work fine. Is there something I may have set that is causing this?
I have set the menu back to the default settings.
  • Canon Master
  • 2,901 Answers
Is there an error message? Have you used it a lot? Shutters do wear out, but there is an error message when that happens.
Posted on May 07, 2014
SOURCE: Can't adjust shutter speed in Tv shutter-priority mode
Download a recent firmware,dude. :-)
Posted on Oct 07, 2007
SOURCE: Nikon D40 won't stay in remote mode
read manual ! you can change it up tp 15min.
Find in Custom Settings > "17 remote duration".
if it is not there change first in SETUP MENU>CSM/Setup menu from "simple" to "full"
Posted on Nov 05, 2007
CanadaBruce
  • 58 Answers
SOURCE: Nikon D80 takes picture but wont set off flash
This could be a faulty unit.  Take it back to where you bought it and hopefully you are still under you warranty.
Posted on Mar 09, 2008
SOURCE: When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Posted on May 25, 2009
SOURCE: Lost all button functionality except power and shutter
There is a secondary battery I suppose for memory retension. It is housed where the other batteries and memory card are, the battery is a CR1220. I replaced that battery and things are working well again.
Posted on Jul 20, 2009
How can I put my Cannon $40D camera to IR mode to use a wireless remote control
The IR mode is the timer mode.. On top the camera press the AF button while rotating the selection dial. You see the icon on top the camera switch from a single square, to several stacked squares, then to a clock with a been. That's the IR mode. if you press the shutter button you active the 10 second timer, air you have a IR trigger the camera will receive in in this mode.
Apr 15, 2013 | Canon EOS 550D Rebel T2i Digital Camera
N65 shutter button failure
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
Jul 04, 2012 | Nikon N65 35mm SLR Camera
It doesn't show images in the monitor and at the same time it doesn't take pictures. thanks and more power!!!
your question is not clear. I see technical point of view. you first should disable flash mode (flash off mode), many case the flash circuit continuously force powering on whenever camera switch on and user can not use momentarily. But you can use only in day light condition if the problem condition. If not, it is shutter unit is effective that can work properly. The shutter unit is inner lens unit assemble. You should then consult to local camera tech. Thank and best regard!
May 21, 2011 | Nikon Coolpix 4300 Digital Camera
Hi, I have a Canon T2i Rebel. When i put the camera in "M" (totally manual), the image doesnt appear in the LCD screen. Everything else works fine in the monitor, but it is as if the lens where...
That's great news, so let's write it up as a solution so that other people who search on here find the right information!
So it appears that the Canon T2i when in manual mode (M) remembers whatever settings you play with, and that these settings are remembered across power cycles; in other words, turning the camera off, or switching to auto before going back to manual does NOT put the settings back to a default.
This gives you the opportunity to set choices that make the screen view totally white or totally black, and unless you realise what you did, you can fear that your camera is broken in some way. At first, I thought this was a user interface flaw, but at least with the screen black or white, you know which way you need to go to get your picture back! The settings that affect brightness are Shutter Speed, Aperture Value, and ISO Rating. They are accessed in manual mode with the thumbwheel, alone, with Av, and after pressing the ISO button, respectively.
One more little bit of trivia: when in manual mode if you don't have live view on, when you half press the shutter, a little indicator comes up on the exposure scale, so that you can see how the settings you've chosen are going to come out.
P.S. I noticed that there was a forum especially for your camera, you might like to join it, it's called t2iforum dot com.
Jan 24, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Hey guys. I use my old vivitar 728AFC flashgun on my canon 550d (T2i). the flash works but does not communicate fully with the camera, however my problem is; when set my camera ss higher than 1/200 it...
Hi, the flash in question will not work in TTL mode even though it has contacts on the bottom that may indicate that it could...... so it will work in auto or manual mode but not adjust itself. All adjustments will have to be made manually.
Sep 14, 2010 | Canon EOS 550D Rebel T2i Digital Camera
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Shutter button fell off Sony Cyber-shot DsC-W5 Camera
I bought a "for parts" dscw50 off ebay & unscrewed the side panels; this allowed me to remove the whole top panel (entire silver piece) & exhange it with the one on my own camera which I had broken the shutter button off of. Works fine now.
Jun 23, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Blurry pictures
Most probably you have incorrectly set your camera to a Camera Record mode other than Auto.
If there is not enough light and you are trying to photograph the scene without flash, (eg. by setting your camera mode to a mode that is programmed not to use flash) then the camera has to compensate for the missing light by keeping its shutter open for a longer period of time so as enough light comes into its sensor.
If your hand shakes during that time, you get blurry images.
Check your camera settings. The Twilight scene mode gives you slower shutter speeds to capture dark, night scenes, but you need to stabilize the camera on a tripod or something, depending on the level of light of the scene you want to photograph. The Twilight Portrait, on the other hand, is the same as Twilight with the addition of flash is used to illuminate a person or foreground subject as well as capturing a night background. This mode also keeps a long shutter time for capturing the night background.
For taking pictures of people, I would suggest you use Auto or Portrait mode where the camera will automatically use fast shutter speeds and flash (if dark).
Hope this helps.
May 22, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony dsc-w50 flash going off before or after shutter has opened and closed
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Jan 20, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
14 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
