Question about Lanzar OPTIHC3004 Opti HC Series 4-Channel Car Stereo Amplifier
Which is better lanzar optihc series or optidrive series
3 Suggested Answers
sumthin
  • 71 Answers
SOURCE: lanzar optidrive series 4000watts mono block digital compitition class amplifier
Firstly, sorry to to tell you, but their is no such thing as a 4000 watt car amp. Google Ohm's law and RMS .
Check the owners manual or website to find the amps minimum impedance. Usually 4 or 2 Ohms. Next,
check the woofers impedance , If unsure check with a Ohmmeter,
It's actually the resistance,but close enough.
If they are 8 Ohm and you twist those wires together (parallel circuit) your amp will see 4 Ohms.
If they are 4 Ohms (paralleled) your amp will see 2 Ohms.
Do not connect in a series circuit (+ amp terminal to a + speaker terminal and that speaker - terminal to the other speakers + terminal and that speakers - terminal to the - amp terminal) .
It creates phase problems, and sounds like ****.
Most mono amps are really internally bridged stereo amps ,it's cheaper that way, but it limits how low of a impedance they will handle. Read the specs. Use the correct size connectors, scrape off paint for a good ground connection.Use the right gauge wire and above all. Fuse that power lead at the Battery!!!!!!!!
ps . if you have dual voice coils thats another chapter.
Good luck, Sumthin
Posted on Jun 11, 2008
EngineerMC
  • 185 Answers
SOURCE: how many watts does the lanzar optidrive 500.2 push out
250w x2 @ 4 ohm,
450w x2 @ 2 ohm,
900w x1 @ 4 ohm
:D
Posted on Apr 26, 2012
Hi! I just inherited a Lanzar OptiDrive 1400D amp. Can anyone direct me to the Lanzar authorized or service centre in Singapore as I intend to send in for a general servicing. Thank you!
It appears that no identified service center exists in Singapore. You might want to try contacting Lanzar customer support directly for assistance: http://www.lanzar.com/ContactUs.aspx
Apr 17, 2015 | General Cell Phones
Is a boss ce2800 amp a good amp it says its 2800 watt class d mono block
It's over rated on it's specs and they run real hot when working hard. Make sure to located in an area with good air flow and away from material that may melt.
Nov 15, 2013 | Car Audio & Video
My Lanzar Optidrive plus has a green light and a red light. I assume this is a sign of safe mode. normally it is just green. How can i get it back to normal and in working order. I already tested other...
your output of the amplifier have been distorted. I suggest you take this to a reputable service technician that has experience with lanzar OptiDrive old school Rockford Fosgate or Orion. These technicians are hard to come by nowadays but they definitely are worth the money that they charge. I happen to be one of those such technicians.
Nov 15, 2010 | Lanzar OPTI 50c Car Audio Amplifier
Looking for a service manual for a Lanzar Viberant 1200W Amp
www.lanzar.com/manuals/VIBE226-236-246-256-266-276-286-416-426-436.pdf
Mar 03, 2010 | Lanzar - Viberant: 2 Channel 1200W...
What is the rms for a single max12d lanzar is it 500rms or 250rms
Description One of the oldest and most respected names in automotive sound is also one of the most consistent winners on the competition circuit. Lanzar offers a wide range of high performance subwoofers, from the pounding OptiDrive Series to the rugged MAX Series. The MAX12 dual-coil subwoofer offers high power handling, great bass response, an economical price, and a 3 year warranty. Specifications: *Power handling: 500 watts RMS/1000 watts peak *VCdia: 2" *Impedance: 4 ohms per coil *Magnet weight: 130 oz. *Fs: 33.6 *SPL: 88 dB 1W/1m *Vas: 3.19 cu. ft. *Qts: 0.47 *Xmax: 10mm *Dimensions: A: 12.09" B: 11.15" C: 6.42"
Oct 27, 2009 | Lanzar MAX12D Car Subwoofer
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Oct 06, 2009 | Car Audio & Video
Want to buy a Capacitor 50mm x 35mm 390 uF 400 volts DC
look in the yellow pages under electronics supplies wholesale.
that is a big capacitor. you may have to parallel 4 100uf @450 volts to make that value.
Sep 10, 2009 | Lanzar Optidrive OPTI100.2 Car Audio...
Lanzar optidrive series 4000watts mono block digital compitition class amplifier
Good luck, Sumthin
Jun 11, 2008 | Lanzar Car Audio & Video
Lanzar OPTIHC3004 Opti HC Series 4-Channel Car Stereo Amplifier Logo
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
