Question about NRS Exercise & Fitness
Stex 8020tx treadmill belt replacement
Hi everybody, i have a stex 8020tx treadmill wich need a new Belt. Where can i buy those (including shipping to europe)? And does someone got a Repair manual for this like there are repair manuals for other brands like Life Fitness? or is it just the same ? Greatz Chris
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: I have a Trotter 535 treadmill. I need to turn
visit wefixfitnessequipment.com and I will tell you how to flip the deck, tighten the belt and where to get lube. If you are planning on flipping the deck make sure you lube it with the right kind of lube!
B. Clark
Trotter/Cybex certified technician
15 years exp.
Posted on Oct 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Posted on Apr 12, 2010
maxtreadmill
  • 832 Answers
SOURCE: How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on May 31, 2010
maxtreadmill
  • 832 Answers
SOURCE: no manual for a weslo cadence 2300 accusmart
go to iconservie.com click on manual input this infoWESLO THEN M# (WL23001)
Posted on Jun 13, 2010
I need a manual for stex 8020t treadmill
Unfortunately no manual is available online but if you contact http://www. synergyfitness. com.au/ they should be able to help you
Aug 16, 2013 | NRS Stex 8020T Treadmill
Stex treadmill about error 2
adjust the Speed sensor, see the diagram, clean it, test for open or faulty, and tight the connector very well.
Lube the deck belt, see the video, lube the rollers bearing front+back too , test the drive belt motor and replace the belt if necessary. God bless you
However you must try to Run the software calibration after your fix it.4d80cf2e-89d9-4476-902b-88e5991886e8.gif
Jul 03, 2013 | NRS Stex 8020T Treadmill
Error code 1
I am the same Problem with Stex 8020 T Error Code 1
Oct 25, 2010 | NRS Stex 8020T Treadmill
Treadmill Stex 8020 when switched on immediately increases speed on board (without touching buttons) until it reaches 250km...the belt isn't moving when this is happening and pressing + or - or other...
If it reaches 250km then I suspect that the upper electronics is not functioning properly contact the distributor of Stex and If under warranty they sould cover it,but send out a servicer
May 03, 2010 | NRS Stex 8020T Treadmill
Belt is slipping, even on the lowest power.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
As far as the manual, I have not been able to found it anywhere yet.
Jan 22, 2009 | NRS Stex 8025TL Attachable 17 Inch Lcd Tv...
Exercise & Fitness Logo
Top NRS Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a NRS Exercise and Fitnes Expert? Answer questions, earn points and help others
