Question about Watches
Can i charge an axivity watch with car charger?
Why won't my Garmin Forerunner 110 charge up ?
you either have a bad charger, bad charger port or a bad battery.
Jul 30, 2014 | Garmin Forerunner 110 GPS Heart Rate...
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
How to fix sea pathfinder tough solar SPS-201
If this is the SPS-201 the band is attached so a surfer/sportsman will not have it come off easily. there are stainless steel clasps around the pins and you may have to pry the clasps off and replace the pins which probably can be found at kmart cheap. Bought this watch from thrift for $4 dead. Took battery out checked at .5 volts enough to charge on mini charger. After a short charge replaced and so far it operates fine. Suspect that if discharged too far, from perhaps placing in a drawarer for a while the watch solar charger has trouble detecting + and - poles and charge from my mini charger is just enough to get it going again. I have done this with other batteries. I will have to replace the band retaing pins but that is just about it. Good luck. Suggest when taking apart draw on paper the orientation of band parts and back and tape parts to a piece of paper so as not to lose before reassembly.
Jun 03, 2012 | Casio Watches
The word "LOW" always appearing
The word LOW means that the solar battery charger is not charging. This could be a defective charger or you're not out in the sun long enough to keep it charged.
Feb 06, 2011 | Casio Protrek Triple Sensor Tough Solar...
Not charging . not nworking battery dead?
mcdevito75 here, If the battery is 2 years old, it could be un--able to accept a charge. Double check instalation into the charger, make sure charger itself is plugged into outlet. If so, visit a small watch repair shop in your area for battery change.
Jun 27, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Need new battery. How do I do that?
Around the outer edge of the watch there will be an indention. Pry open with a small screwdriver. Your internal compartment should be right there.
May 05, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
The ladies disney citzen eco-drive requires a charge
Follow this link:
http://www.citizenwatch.com/CUK/English/settings.asp
Interactive settings are helpful as well.
Rate me, please.
Apr 06, 2009 | Citizen Eco-Drive JR3080-51L Wrist Watch
After full battery drain, no function
Hello FixYa,
How I solved the problem ???
Read my former post again.
I thought this could help you with your troubleshoot database.
Ragards, Marc
Dec 01, 2008 | Citizen Promaster Cyber Aqualand Nx Dive...
Watches Logo
11 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
