Question about Home Fencing
HOW DO I RESET A GATE OPERATOR?
HOW TO CHANGE A PASSWORD TO ENABLE GATE OPERATOR
I forgot my login password i can not acsess my laptop how can i?
First you will need to enable the built in Administrator account in the operating system. You will find instructions here: http://social.technet.microsoft.com/wiki/contents/articles/3040.enable-disable-the-local-hidden-built-in-administrator-account-in-windows-7.aspx You may need to start in "Safe Mode" to be able to do the steps required to enable this account. Once you enable then log into the Administrator account you can them go to Control Panel - User Accounts - manage accounts and find your account and change the password.
Nov 15, 2014 | Microsoft Windows XP Home Edition
Tip
How to enable Windows 7 administrator account and reset lost Win 7 admin...
How to enable Windows 7 administrator account and reset lost Win 7 admin password
There are two parts for your Windows 7:
* Enable Windows 7 administrator account
* Reset lost Win 7 admin password
With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods.
Part I: Enable Windows 7 administrator account
Method 1: Use Command Prompt
The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt.
1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator.
2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear.
3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled.
4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account.
Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps:
1. Switch to log on Windows 7 with the administrator account.
2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account.
3. Click Create a password for your account on the screen.
4. In the coming screen, type and confirm your Win 7 admin password.
5. Enter password hint and click Create Password.
Now your Windows 7 admin password is successfully created.
Method 2: Use Local Users and Groups
1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up.
2. Double-click the Users folder. And all the Windows 7 account will be displayed for you.
3. Right-click the Administrator account and select Properties.
4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen.
Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below:
1. Right-click the Administrator account and select Set Password.
2. Click Proceed to go on your operation
3. Type and confirm your new Win 7 admin password and click Ok
4. Close the Local Users and Groups screen.
Now the Windows 7 administrator password is assigned to your Windows 7 admin account.
Part II: Reset lost Win 7 admin password
Windows 7 administrator password reset Tips:
Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows.
Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password.
step 1. Download and install Windows Password Breaker.
step 2. Run the program and burn a Windows password reset disk.
Step 3. Reset Windows 7 administrator password with the disk.
It is an easy and safe way for Windows 7 admin password reset.
on Nov 02, 2010 | Computers & Internet
Reset password
Windows operating systems allow you to set up an administrator password, which prevents unauthorized users from downloading applications and making system changes without your permission.
If you have forgotten your administrator password, you can reset it easily and create a new one that you can use to log into Windows.
Since Acer Aspire computers use Windows operating systems, resetting your password is a simple process you can accomplish in minutes.
Restart the Acer Aspire.
When Windows boots up, select the username you want to reset the password for and press "Enter."
Click "Use your password reset disk" to launch the password reset wizard. The password reset wizard enables you to create a new password for your user account.
Click "Next" on the password reset wizard and insert the password reset disk.
Click "Next."
Type your new password in the "Type a new password" box and type the password again in the confirmation box.
Type a hint to you use in case you forget your password next time.
Click "Finish" to activate your new password.
Restart your computer and log on to Windows using your new password.
Nov 26, 2013 | Acer Aspire One Netbook
Password reset
Restart the Acer Aspire. When Windows boots up, select the username you want to reset the password for and press "Enter."
Click "Next."
Reset your Windows password
http://windows.microsoft.com/en-US/windows-vista/Reset-your-Windows-password
Aug 13, 2013 | Acer Aspire One PC Notebook
Acer E1 571
Click "Next."
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password
May 16, 2013 | Acer Aspire E1-571-6650 Laptop
How can I reset my system password?
Disabling a Forgotten Password
If you forget the system password, you will be unable to operate the system until disabling the password. Disabling the password involves going inside the computer and changing a jumper setting (twice) on the system board.
To disable a forgotten password, perform the following steps:
  1. Turn off the system and remove the cover.
  2. Move the jumper plug on jumper A to pins 2 and 3 to disable the password(s).
  3. Turn on the computer. Powering up the system with jumper A set to the disabled position erases existing password(s). Before assigning a new system password, you must reset jumper A to the enabled position.
  4. Turn off the computer.
  5. Place a jumper plug on pins 1 and 2 of jumper A to enable the password features.
  6. Replace the computer cover.
Dec 28, 2012 | Dell Latitude E4300 Notebook
Acer P1265 projector asking for password
Security
This projector provides a useful security function for the
administrator to manage usage of the projector .
Press to change the "Security" setting. If the security function
is enabled, your must enter the "Administrator Password" first
before changing the security settings.
• Select "On" to enable the security function. The user has to
enter a password to operate the projector. Please refer to the
"User Password" section for details.
• If "Off" is selected, then the user can turn on the projector
without password.
Feb 06, 2012 | Acer P1265 DLP Projector
I have a wire less modem but the connection is very slow after some days, may be the password is noted by other computer, please provide me the method to fix gate way password and in case i forget the...
The easiest way of recovering your modems password when you forget it would be by resetting the router to defaults. This will reset the password to the origioal one it had when you bought it, this should be somewhere in the manual or similar. Once it has been reset change it to something that you can easily remember but still something secure enough not to be hacked/guess so easily (try to use at least one capital letter and one number)
Mar 01, 2011 | Computers & Internet
How do I remove the Touch tone/pulse option. This message has recently appeared without knowing how it go there. It was never there before. ''If you are calling from a touch tone phone please press 1 now,...
Sounds like your touchtone gate has been enabled in your voicemail. To disable the touch tone gate enter feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press 1, the display should say TT gate:std chng and ok. press the chng key til it says none and press ok press the rls key when finished.
Jan 11, 2010 | Nortel T7316E 2-Line Corded Phone
RESET PASSWORD
Soluton 1. if this windows user password, what operating are you using? if you are using operating system xp. you can download the program on, www.isohunt.com just type: password changer, or Hiren's program,.. burn on cd then restart you computer, then select boot menu by preesing F12, be sure that F12 booting menu is ON. if not go to Cmos then make Enable..
Solution 2. if this password from the Cmos or Bios Password, Reset by removing withen few second the small battery inside in your laptop...
if you can't contact me > alexandercalidguid@gmail.com
Thanks
May 25, 2009 | Acer Aspire 5610-2328 Notebook
Home Fencing Logo
112 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
