Question about Mio 0021usblk2 Drive Petite Hrm Black Monitor Watch
Watch is frozen, will not reset or change modes
Was resetting watch after replacing battery and now watch is frozen and will not change modes or reset
    Problem Solver:
  • 19 Answers
You will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
Posted on May 10, 2014
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Hi, my nike triax cv10 watch is frozen, tried pressing all the buttons at once but no luck please help?
The display of your watch may "freeze" due to static electricity or recent battery replacement.
If this occurs, press and hold all four buttons at the same time.
This will erase the data in the memory and allow you to reset the watch to the factory settings.
Press and hold all four side buttons at the same time to reset the watch to the factory settings.
Hope this helps.
Sep 14, 2013 | Watches
I have a gw-500a and the battery got replaced with a brand new one, but my watch still says charge and it won't let me change the mode or anything. The time is on the screen though. Please help
You have to reset this watch after battery replacement. Using tweezers or something similar you have to touch the AC & - contact on back of watch, for 2 seconds. Hope this helps.
Dec 23, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Seiko M705 - 5A10 series divers watch. Time is Frozen
Have the batteries checked and an "AC" done to it. These watches generally have several batteries and the die off can be slow and only fail partially. The "AC" or all clear function will reset the circuit board and bring all your functions back.
As with any dive watch, be sure that you take it to a watch maker/technician that can reseal and pressure test the watch to insure it is safe for diving.
Sep 18, 2009 | Watches
F55 watch is frozen and cannot get back to main
HI dyer_christi
Most of these watches hold there memory whilst the batteries is still in. Unfortunately the best thing to do is to remove the battery and reset all data! I know this means you loose the hard work you have done, but I do not know of any other solution? Are you capable of changing the battery or would you like some help? I can provide additional assistance with this if you'd like. You need a small philips head screwdriver, some small tweezers and a clean bench with a few mins (say 30). if you'd like I'll help you through
Jul 15, 2009 | Polar F6 Wrist Watch
Watch settings
Press MODE and it jumps to Timer. Press mode again and jumps to ALARM set. press MODE quickly and jumps to time set. press START/STOP to reset and press RESET to change to minutes or hours. press RESET again and changes to Date Set...
Sep 17, 2008 | Watches
Need to reset Ultrak 510 soccer watch
To set time and date:
Press and hold upper left button
Upper right resets seconds
Lower left changes item you wish to reset
Upper right moves number to next higher
cycle through using lower left
when finished push on upper left
In timer mode to reset timer:
use upper right to reset minutes
In alarm mode press and hold upper left
press upper left when finished
upper right toggles alarm on or off
Feb 12, 2008 | Watches
Hour and second hands on my Casio Wave Ceptor watch appear to have frozen
They ususally say leave it alone for about 3-4 minutes and it goes back to time keeping mode. Or - you have "turned it off" a feature to conserve the battery while it sits in you drawer.
Manuals can be downloaded from Casio at
http://world.casio.com/wat/download/en/manual/
Dec 29, 2007 | Watches
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Mio 0021usblk2 Drive Petite Hrm Black Monitor Watch Logo
498 people viewed this question
Top Mio Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Mio Watch Expert? Answer questions, earn points and help others
