Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Not getting spark in craftsman tractor lawnmower
No spark, already changed sparkplug, checked wire for damage, fuse ok
  • 41 Answers
How old is the engine? Does it have electronic ignition or points? Check the engine stop wire where it attaches to the throttle control on the engine. Make sure it is not grounding out. Has the magneto been removed? That is the Y shaped part behind the flywheel, where the spak plug wire attaches. If the mag has benn removed, it needs to be re-adjusted. The correct gap is .020 of an inch, about the thickness of a matchbook. This gap is measured between the two legs of the mag and the flywheel. I hope this helps, good luck.
Posted on May 07, 2014
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Not getting fire to new sparkplug
first does it turn over at all. if then check to see if the blades are turned off, out of reverse seat interlock ect.
Jul 21, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 42in rider quits after about 30 to 45 minutes. The carb solenoid is good and the gas cap is venting ok. I have to wait about 20 to 30 minutes before it will start again. What should I check...
try the coil,does it get fire to the sparkplug after it quits and what color is the spark? blue spark is good, red is weak fire, and not enough to fire the engine up.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark
try sanding ends of magnito and check the wire from magnito to sparkplug and see if its broke.
May 24, 2009 | THQ The Lawnmower Man
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
No spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
Apr 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
83 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
