Question about Kyocera FS-4000DN Laser Printer
1010:0455544 The printer is displaying the above error code, I have all the parts for this machine, I need to know which one to change.
    Scholar:
  • 51 Answers
This error code indicates a problem related to paper cassette lift mechanism. First thing that you will need to check is, if the printer makes some strange noises at initialization, when the printer is trying to lift the paper inside cassette. You can verify if the lift mechanism on the printer is ok, by removing paper cassette and press the 3 small white switches on the left of printer. At this moment the printer is trying to lift the cassette and you will see a gear that rotates on the right side of printer. Also verify if the GEAR LIFT Z64 is intact by opening the gearbox(the big one from the gears from the right side of paper cassette). This gear is cracked in most cases. Replace it.
Posted on Jan 29, 2015
Error code E000202-001
The error code deals with the scanner unit / scanning lamp. Have you just cleaned the optic's???? Was the problem there before you started to work on it? Dos the scanner lamp turn ON? I the lamp dos not come on, you will need to replace the lamp and the lamp regulator PCB at the same time as a set. Very,very important... They need to be changed as a set. If you have a working parts machine, I would use the parts from the parts copier. Good Luck
Jan 27, 2013 | Canon imageRUNNER 2200
Hi, my printer does not print and on display gives me error 77 i don't know if this is worth to get it fix or jus get a new one if u can give me some help? Thanks Al.
You are probably getting errors 76,77 and 78. All of which point to a fuser fault. The 9070 is a great machine and i would certainly get it repaired. in fact the fuser is easy to change. Open the main cover and it is at the front of the machine. Its the long black covered part with yellow writing on it warning you is maybe very hot. there are just two screws at each end to remove. Lift and the fuser will come out. Be careful as there are wires under it that need to be disconnected. Repair is just a reversal of the above.
Jul 05, 2011 | Brother MFC-9070 All-In-One Laser Printer
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Canon ir1570f printer system error E247
Hi rapsherp,
Cause: Error with Serial Number PCB or Counter PCB or Main Controller PCB
Remarks: Please complete online form to order Controlled Parts via Dealer Net or Canon Intranet, and send to Information Management Group.
The E247 code relates to a problem with either of the above three boards, which are a controlled parts from Canon with the exception of the main controller.
If you change any of the above boards the other two must come from the same machine as they each 'write' to each other to ensure everything matches up.
Given the age of these machines and the cost of the boards it would be cheaper to upgrade to a newer model.
Hope this helps.
Thank you for using FixYa.
Dec 23, 2010 | Canon 2050P Printer
CHECK PRINTER ##330 flashing message
From the message board archives:
Error codes:
## 322 Fuser not heating (Usually Bad Fuser Module)
## 323 Laser Beam detect error
## 324 Laser scanner motor rotation incorrect
## 325 Fan motor inop
## 330 Power Supply (Replace/Repair)
You must turn on error management to have the machine display error codes, otherwise it will just say "CHECK PRINTER".
To turn error management on, enter the following: Press Data registration, #, Set, 00000011, set, stop. Now after the "check printer" message there should be one of the error codes above.
Supposedly, Nation-Wide Repair Service fixes the bad power supplies for $45.00. They can be reached at 800-798-1814. You can also buy one for $148.00 from www.loyal.net I hear. The proper replacement power supply part number for both the LC7000 and LC7500 is HH3-5278 so I am told.
Aug 04, 2009 | Canon LaserCLASS 7500 Plain Paper Fax
10.10.00 supply memory error coming on HP Laserjet 5200 Printer.
Dear Sir,
I has change the printer cartridge. After changing the printer cartridge above mentation comming. When I am making printer power on the (10.10.00 supply memory error) display. Please tell me how to solve this problem. Best regards,
Thanking
Ajom Khan Hero
Mobil No.092 5192797.
Al Nahr Co.Ltd
Tripoli - Libya
Jun 17, 2009 | HP Hewlett Packard LaserJet 5200 Printer
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Nov 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Kyocera FS-4000DN Laser Printer Logo
127 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
