Question about Amana Dryers
Amana electric dryer will heat but only when.../ LEA60AW
I have to lift the back part of dryer up and drop it just about 1/2 an inch to 1''. I am guessing it needs to catch on something.
ONce I do this it heats up ok.
I have been doing this now for about 3 mos.
Husband has already checked to see if something is loose.
We cannot seem to find anything.
suggestions?
Thanks!
Paddi
  • 2 more comments
  • pingo357 Jun 23, 2009
    Sorry....I was at work....well, still can't find the loose connection and now after trying to dry one last load last night. The dryer will not even come on. When you push the knob in, nothing happens.
    Suggestions ....?
    Dryer does not have a display.
  • pingo357 Jun 30, 2009
    The heating element has already been replaced....this is when I started to have this problem.
    No one has given me a NEW solution.
    I will continue to see what I can find.
    The knob does not turn any longer...maybe you can answer this one....
    I have been charged twice already with no "real" answers and I have not accepted either of the replies becuase it is nothing new.
    I am gettign a bit frustrated, being taken twice.
    Is this thr norm with this website?
    Paddi
  • pingo357 Jul 12, 2009
    This problem has been resolved...your company has already taken payment four times....only one was close to resolving the problem. Not real happy about getting taken each time someone responded.
    I actually figured it before I was able to get back on line. no loose wires.....and the knob not turning was a given that something was broken I had an extra knob and replaced.it right after I sent message...it was the Timer the entire time...this was causing it not to heat!!!!.I am sorry thought it was a much bigger project.If anyone can get someone to take off three of the four (only approved for a one time charge) deductions I would greatly appreciated this. I have contacted company but NO ONE SEEMS TO HELP.
    Greatly appreciaye anyones help!
    tks!
    P. Castillo
    Sergeant:
  • 340 Answers
The heating element needs replacing . what you are doing is by dropping it connects the element for a short time. the drum needs to be pulled to access the element unplug the drier should be a couple screws when you open the door pretty easy to take apart pull the drum the element is behind it. I would get a restring kit online appliance parts ya need the model and serial # the biggest cause of drier element failure is plugged drier vent. clean that it will make the drier work more efficiently lower electric bill. good luck. it is helpful to have 3 hands for 1st timers putting the drier belt back on. Tom
Posted on Jun 24, 2009
  • taa43 Jul 01, 2009
    If you replaced the element was it hooked up correctly? the dryer has high limit klixons to prevent over heating that could be bad you would need an ohm meter to check continuity at this point i recommend getting a qualified service any thing else I suggest you would need a meter. Tom
    and you are going to need a new control knob since it wont turn any more . Tom
  • 3,230 Answers
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Posted on Jun 22, 2009
  • Mukesh Kumar Jun 23, 2009
    Is there any error code on display?
Amana dryer lea60aw.when dryer is plugged in and door open, timer is ticking and recently replaced heating element is giving off heat-does the timer need to be replaced? or is it a thermoststat/ etc.?
It should not be on sounds to me like the cent switch inthe motor needs replacement. Common on amana dryer motors, not too hard to fix. See if it slides easy by hand and oil it cleaning out any lint that may have accumulated in the swtich. The job of the switch is to power on the heating element ONLY when the motor gets up to speed and centrifugal force slides out wrights on the switch allowing for power to go to the heater element . Switch stuck most likely, let me know.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 11, 2017 | Amana Dryers
My dryer is overheating. Clothes are so hot you can't handle them. Amana electric model LEA60AW
You control thermostat is not working. Replace it. It mounts on the blower housing. After making sure the blower is not loose replace the stat. It is the only thing that controls the temp. The limits shut down the element if the control stat fails to do so. Them clothes is getting too hot because the 250f limit on the element is shutting down the element. The fuse is not blowing because it is rated for 350f. Therefore with the control stat inoperable the clothes is getting too hot.
Apr 10, 2013 | Amana Dryers
Replaced the thermostat and high limit regulator on my amana comercial dryer lea60aw but forgot to tag wires, starting from the thermostat on the blower, i'm not sure where the wires go to, i have
if i were there i could tell you.just think about it .the wires have to make a path all the way through the element.it should have a wiring diagram in the control panel that will help you trace the path.hope this helps.
Dec 04, 2017 | Amana Dryers
I have an Amana Electric dryer LEA60AW. The heating element was open and I replaced it. The new one shows 10 ohms and the two attached bits show 0 ohms. It still does not heat. There seems to be two...
I believe those two thermostats you are looking at are called limit switches. Both should measure 0 ohms. Sounds like you need to replace the one you're calling the black plastic molded one.
Apr 16, 2011 | Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana electric dryer will not heat....LEA60AW
check your wall vent to make sure it's not clogged,also check the fuse on the heater box it may have blown,without the fuse the heater will not work,you can check it with an omns meter-mike
Feb 23, 2009 | Dryers
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Jan 17, 2009 | Amana NDE2335AY Electric Dryer
Dryers Logo
151 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Amana Dryer Expert? Answer questions, earn points and help others
