Coffee Makers & Espresso Machines Logo
L
Lucille Tanguay Posted on May 06, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my Keurig coffee maker heat the water, flash brewing but does not pump the water?
Jay Plesset
Level 3:
  • Master 2,942 Answers
  • Posted on May 07, 2014
Jay Plesset
Master
Level 3:
Answers
2942
Questions
Helped
667493
Points
9879
Pipe likely clogged.
Try running vinegar through it a couple times.
5 Related Answers
Anonymous
  • Posted on Mar 02, 2009
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Anonymous
  • 51 Answers
  • Posted on Feb 03, 2010
SOURCE: Keurig coffee maker is on, lights lit, machine
Even though the light is on, this does not mean the element that heats the water is working. After you fill the machine with COLD water, and the light has been on for a few minutes, unplug the machine and dump the water out into a bowl. Carefully, feel the water. Is it hot? OR just warm? Or still cold? If it is warm, the element is not heating properly. If it is cold, the element is NOT working. If the water is HOT, then perhaps the tube from the water storage reservoir to the brewing basket is clogged. If that tube is clogged, it needs to be removed from the machine and cleaned out. If the element is not working, or heating the eater hot enough, that element needs replacement. Chances are, the replacement cost/cost of repair would be more then a new coffee maker.
Anonymous
  • 58 Answers
  • Posted on Jun 24, 2010
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Anonymous
  • 40 Answers
  • Posted on Oct 07, 2010
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2010
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Shutting itself off
There are a couple reasons that the B70 might stop in the middle of brewing so one cannot be certain. The first one is where there are calcium carbonate deposits on the heating element and as the water in the boiler is agitated during pumping there is inadequate heating from the heating element and the thermostat shuts the brewing off when cooler water rises to the thermostat. Try running a mixture of 50/50 white vinegar through the unit a couple timesxto dissolve the calcium deposits or descale the unit per Keurig instructions. Secondly, it could be a faulty thermostat. If you are not handy, mechanically oriented I suggest buying a new one is best, least expensive. I believe that keurig coffee makers are able to brew 5000 cups without a problem. However our experience is that units with more than 5000 brews are prone to leakage, electricalr problems.
Keurig Leaks Water Before Brewing
If it is in warranty, this unit needs factory services. Unfortunately the cheap labor and rapid production rates are more important to the company than Quality.
2helpful
Small cup, add water, heating lights keep flashing after brew
I had this problem too.
I just pressed the small brew button; it pulled some water from the reservoir and heated it but nothing came out. Then I opened and closed the top cop thing and both the cup sizes were flashing and it worked like normal again.
2helpful
Quit pumping water
all lights are flashing and nothing is happening, water is full and kcup is in?? i thought turning the power off and back on will reset but even that didn't work.
Pls help
Keurig shuts off as water heats and as coffee is brewing?
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
