Question about Maximatic "Maxi-Matic ETO-180 Elite Gourmet 18-Liter Toaster Oven, Silver"
Timer button has broken into litle pieces
Only have had this toaster oven one month,now today when I went to turn it the timer nob broke into small pieces
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Recall: I bought a Euro Pro Convection/Toaster Oven w/Rotisserie and it caught fire today from a non-food related problem. Is there a recall on this item? There was no food in the oven and it was...
Today I was warming up a baked potato in mine it was on 350for about 20 min when I went to shut it off the nob melted right off the ovenit was so hot I could not shut it off had to unplug it and the top of the ovenwas also very hot, is there any recalls on the MODEL # TO161
Jul 11, 2009 | Toaster Ovens
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
May 04, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Kenmore toaster oven timer knob broken
I have the same toaster oven and my timer knob just broke 2 days ago. Go to SearsPartDirect.com website. They have a substitute timer knob.
Mar 18, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Broken Timer knob
Hi Krusin,
Go to
http://prc.prodregister.com/prodprotect/applica/
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/gf.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 10, 2008 | George Foreman GRV660 Toaster Oven with...
Oster Toaster Oven Model # 6192-33
Aug 28, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Maximatic "Maxi-Matic ETO-180 Elite Gourmet 18-Liter Toaster Oven, Silver" Logo
27 people viewed this question
Top Maximatic Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Maximatic Toaster Oven Expert? Answer questions, earn points and help others
