Question about Roper RAS6233KQ Top Load Washer
My washing machine won't stop
When "ON", it will go from setting to setting. i.e. finish "normal", run "permanent press", then run "gentle". If off, the timer keeps turning (doesn't run cycles, just turns).
  • 641 Answers
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Posted on Jul 26, 2007
  • 1073 Answers
SOURCE: Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Posted on Apr 20, 2008
  • 172 Answers
SOURCE: roper washer frozen drive?
I would first check the lid switch and the plunger that pushes the lid switch. If both are good I would make sure the machine is washing properly. If the machine will not wash or spin you have a bad coupling. If the washer will wash then stop at the spin it is usually a bad lid switch, or transmission. The transmission will have a 5 year warranty. It is also possible that you have an object stuck under the main wash tub. You can remove the cabinet and look for objects or you can remove the wash basket itself. Good luck with your repair.
Mike
Posted on Oct 28, 2008
  • 99 Answers
SOURCE: simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Posted on Feb 06, 2009
mumma_1
  • 903 Answers
SOURCE: washing machine won't drain and spin after rinse
It sounds like you have a blocked pump. I have read that the pump is connected directly to the motor. You will need some tools at hand before you try to disconnect the pump from the motor.
Make sure that you disconnect the machine from the power supply. Tilt the machine back to access the pump from the bottom of the machine. It will be connected to the motor with clips. Have some towels ready to mop up the water.
I hope this works for you.
Posted on Jul 27, 2011
My washing machine won't stop-
sounds like you blown the timer replacement?
May 06, 2014 | Roper RAS6233KQ Top Load Washer
Electrolux 8kg won't run
This is probably normal operation , you can press the start/pause and cancel button at the same time to see if you have a error , if you get E00 this means no error if you get a E21 (example) then look and see what that error is
Feb 20, 2013 | Electrolux Washing Machines
Bosch Washing Machine will not execute Wash cycle.
The brushes in the motor are worn out and need to be replaced or there is a problem with the belt or pulley. This is a fairly easy job and much cheaper than buying the motor. Access from the rear panel. If the belt is OK, remove it and then unbolt the motor, disconnect the wiring and remove the motor. If you are unfamiliar with where the brushes are located, then find someone with a little experience to help pop the old ones out and install the new ones.
Feb 14, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
Kenmore 80 series top load washer. In the permanent press mode the machine will stop when it moves to the rinse mode. I can manually move the time past the midpoint of the cycle it will run for a minute...
So it will spin and drain when put in the spin cycle right? More than likely it is your timer if you have to keep manually setting. I would check on timer prices and go from there.
Dec 28, 2010 | Kenmore Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
