Question about Canon Office Equipment & Supplies
Why does my Canon MP49D calculator print light?
I put in a new ribbon and still not printing red and black is very light.
    Top Expert:
  • Canon Master
  • 6,702 Answers
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
Posted on May 08, 2014
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
Replacement ribbon for canon mp-11dx calculator
I did replace the ribbon correctly. I used a universal replacement. the black part of the ribbon in on the top and the red at the bottom but I am not able to print clearly on the tape. What would be my problem?
Sep 23, 2012 | Canon MP-11DX Calculator
I need a manual for my new canon mp49d
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/calculator/MP49D.pdf
Aug 17, 2011 | Canon MP49D Calculator
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
Canon p170-dh
if you calculkator does not print at all try to move a switch to p or print, and you have a ink roller on the printer
Dec 08, 2007 | Canon P170-DH Calculator
PRINT COLOR
Hi...it appears that the ribbon is on upside down..The black has to be on the top and the red on the bottom. Just switch spools and turn the ribbon over..either that or there is a spring off the ribbon platform solenoid on the right side of the printer just below where the ribbon comes off the spool. If the spring is off or broken the ribbon platform will rise too high and print in red. Remotely the solenoid (little blue thing) could be bad or out of adjustment.
Hope this helps..this is usually all it can be.
Squipps
Nov 27, 2007 | Sharp EL-1750PIII Calculator
424 people viewed this question
old marine
old marine
