Question about Frigidaire Refrigerators
Water valve on Frigidaire side/side model FRS6R4EB6 refrigerator
Have water valve with solenoid valve for main water supply line to filter which works when door water supply is activated. However, the other two solenoids that supply water to door water spicket and ice maker do not open and no water is supplied to either of these. Have good volume and pressure from the main line coming back from the filter to the water/ice maker valve/solenoid assembly. When door switch is activated the solenoid only buzzes and doesn't open. Have cleaned orfices and made sure water lines and valves are clear of obstructions. Thanks for any info in advance. Jon from OK
5 Suggested Answers
SOURCE: Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
Posted on Sep 01, 2007
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
SOURCE: Frigidaire Fridge -- water stopped working
change water filter
Posted on Jul 22, 2009
espressonist
  • 1711 Answers
SOURCE: I've got a GE /Hot
As you may already understand the issue is the solenoid valve. And this due to the movement probably some dirt block the valve passage with is a very small hole. Or the coil- magnet has gone bad. So either you need to disassemble the solenoid valve despite that is factory sealed the solenoid can be dismantle be cleaned and tested and then put back again. This need special skills and experience in order to succeed.
You don't have to lose anything to try since in any case if you don't succeed you would need a new solenoid in any case.
Also from your detail description you don
Posted on Oct 31, 2010
No ice or water coming out
Assuming the water is turned on and ice available to dispense, look for the lock on the dispenser. Most units have a lock to keep small people from playing with the water dispenser. Almost all units do not have a drain on the dispenser and by placing the unit in lock out, keeps the water from overflowing and damaging the floor. On most unit, find the lock and hold 5 to 10 seconds and then try the dispenser again.
If it is not locked out, your control card may have had damage done to it and the control card will probably need changing out. If your system is under warranty, call the 800 number and pay the small service fee and the technician can get the parts under warranty and sometimes the warranty also covers the labor. The technician will have to file a claim to the warranty department.
If you do not have water or ice, your problem is either the supply water has been shut off or your solenoid operated dual water vavle is malfuctioning and needs to be replaced. These dual water valve do have an upstream strainer that can get clogged and needs to be flushed or replaced. The strainer is part of the solenoid operated dual water valve.
Hope this helps.
Jan 02, 2015 | Samsung Refrigerators
Water dispenser on Frigidaire FRS6R5E refrigerator is not working but ice maker is working fine.when i open the filter area & press the water dispenser button water comes out from that area & when i put in...
At the back cover of the fridge you will find a double electric valve. The easy way to find valve is to follow water supply tube to your fridge
Unplug fridge and check with multimeter if one of the coils burned out and should be replaced. Make sure you close water shut off valve before removing solenoid. Good luck
Nov 14, 2013 | Frigidaire FRS6R5E Stainless Steel Side by...
We own a Kenmore Side by side refrigerator, model #253.54622406. The water has stopped coming out of the water dispenser in the door. What could cause this?
if the ice is opperating normaly listen for a click or humm from the water valve if nothing it may be the switch first check for power at the valve when switch depressed if present replace the valve if valve has power and you hear it oppening and closing it or the line to the dispenser may be plugged. if no ice either check the water supply to the fridge and the filter in the fridge if there is one.
Mar 08, 2011 | Kenmore Refrigerators
Side/side frigidaire not dispensing water & no ice-replaced filter-opened up back of unit- cleaned up- water coming all the way to the frige from house main- hear regular noise like when it wants to...
your double water valve is the problem. solenoid is probably stuck(located on water valve) just replace with new one. water line is connected directly to water valve which is attached w/a couple of screws. hope this helps.
Dec 25, 2010 | Frigidaire PLHS269ZC Side by Side...
I need a bypass filter for my Frigidaire refrigerator, Model FSC23F7DSB. I have an RO unit pumping water to the frige but hte filter in the refrigerator is doing two things. First it is contaminating the...
I looked for a bypass for your models but none listed . just remove the cartridge. this should work. you could also by pass the filter by connection the two lines lik they do on water softners. . valve or connector in back .. now a word to the wise . they do not recommend hooking the frig up to r. systems as the do not produce enough pressure to the main valve to shut if off ( sometimes ) thus causing a flood . if you do use 3/8 or better line size . this will help .. **** . hope this helped . mm
Dec 23, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Filtered water quit working on my Frididaire side by side
Can you remove a line from the back rear of the unit and see if water flows there? The solenoid valve should make a solid "click" when the water lever is pushed. Any debris in the valve filter screen? See if you can reach up or look inside to see if the water lever is actually pushing the door mounted switch in, may be able to press switch with your finger if you can reach it or with a pencil, etc.
Aug 20, 2006 | Frigidaire StandardDepth Side-By-Side...
Refrigerators Logo
227 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
