Question about Canon imagePROGRAF iPF8000 Printer
How to determine problem - making noise at every startup
Noise startup
Have your valve lash adjusted. Overhead cams need the lash done every 25-30K otherwise after some time they make a loud ticking sound. If the motor makes a "Knocking" sound, it may be a lower end noise, and there is no adjustment for that.
Jun 17, 2013 | Hyundai Santa Fe Cars & Trucks
I have a Whirlpool Duet Dryer about 4 years old. It just began making a screeching sound at startup. I say startup because it subsides after awhile. It sounds like a bad bearing , but acts like its a bad...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 06, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool gas dryer Model LA 1580 /WO. The dryer makes a loud screeching noise. Could you determine the likely cause? Thanks, Dennis
heatman101
Asker
Dec 27, 2010 | Whirlpool Dryers
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Dryer squeaks on startup
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Nov 22, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Sears Kenmore clothes dryer 11072812101 noise at startup.
Its either a belt, roller bearings, the tensioner, or the bearings in the motor.
Each is replaceable, but to find out the problem you are having, you will need to remove the panels of the dryer and inspect each one.
hope this helps
Aug 13, 2009 | Kenmore Dryers
Ticking Noise at Startup
Possibly a leaking hydraulic lifter. They can leak down while engine isn't running and then make a ticking noise for a while on startup. If it takes 10-15 minutes to go away, it is more likely to be a loose tappet which needs adjusting.
Aug 02, 2009 | 1995 Buick Riviera
Toshiba laptop is slow and keeps making strange noises!
When any portion of the electronic package begins or is failing it can very well cause other problems. The different sections of your laptop all share power supply lines, cpu freq lines and memory lines. I agree that the hard drive could also be a culprit. Now you'll need to determine if this is an actual hard drive physical problem or is it virus' and spyware playing with the operating system. Is this what you paid that company to do? If so I'd be back there is a minute. What are the beep codes you're hearing?
Apr 15, 2009 | Toshiba Satellite Pro A200-EZ2204X...
My PC generally runs slow and takes a long time boot-up
You need to give more information, especially what operating system you are running. Lets presume its Windows XP...
Your PC is likely loading a lot of applications at startup that are taking so long to load and settle down. You can determine if this is the issue by doing the following:
  1. Click "Start" button and then "Run..."
  2. Type in "msconfig" and click "OK"
  3. Select the "Diagnostic startup" option and then "Apply"
  4. Follow reboot options and when rebooted see if this improves your startup/speed
  5. If it does (it should) then you can browse the list of applications you are loading (the "Startup" tab) and turn them on one by one until you find the offending application.
  6. Once found, either leave it off the startup list in msconfig, or uninstall it completely.
Another option that is less technical is to install an application like Norton Systemworks/360. It's speedstart utility is a more user-friendly version of msconfig and can automate the process of eliminating the startup and system hogs in your list of startup applications. Be warned that if your anti-virus software i not Norton you'll have to uninstall it as Norton's doesn't play well with others. However Norton's anti-virus does a superb job so you'll still be protected.
Hope this helps.
Dec 28, 2008 | Computers & Internet
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Jan 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Canon imagePROGRAF  iPF8000 Printer Logo
21 people viewed this question
old marine
old marine
