Question about Refrigerators
Make: true, model: gdm-35, can someone please tell me where the stater for fluorescent lights are? Thank you in advance :)
    Habit-Forming:
    New Friend:
  • 82 Answers
Not sure what a GDM 35 is but if it has a ballast, take the back off and look for a module with wires coming and going.
Posted on May 06, 2014
5 Suggested Answers
  • 135 Answers
SOURCE: True Model GDM 10 Not
try to replacemen the relay
Posted on Jan 09, 2011
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
  • 79 Answers
SOURCE: where do i find the starters for the florescent
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Posted on Nov 12, 2009
  • 1165 Answers
SOURCE: Why won't my inside lights
usually controlled by a switch located either in the door hinge or at the top of the door. Be sure the bulbs are good and of the correct voltage.
Start there and let me know if I can be of further help.
Posted on Mar 24, 2011
Yesterday, I had a cook talk to someone about our reach in fridge door coming off ...i model GDM-26
Here is the parts list. http://beverageequipmentcompany.com/true/GDM%20Models/GDM-26%20Models%20Parts%20Listing.pdf
www.beverageequipmentcompany.com
Be advised that the hinge is a multiple part assembly with brackets, bushings, blocks ect. You might want to contact them to see what all you need
Apr 28, 2017 | Refrigerators
I had True Refrigerator model GDM 06, It was cold and freed all my stuffs. I try to adjust temperature warmer, but unable to locate the temperature controller. Please help. Thanks
I had the same thing happen to me and all I needed to do was vacuum the coils of refrigerator. Try this 1st. Thank you. Please leave feedback
Jul 10, 2016 | True Refrigerators
AT WHAT TEMPERATURE SHOULD I SET MY TRUE GDM-10 REFRIGERATOR 1,O,9,8?
You need to put a thermometer inside with what you are storing. The numbers will vary and are for reference only. Temperature should be 35 to 37 degrees f. Adjust number on dial once every 2 hours or so. Give the system time to react and cycle at least 3 times before taking a temperature reading. Good luck and hope this helps.
Sep 27, 2014 | True GDM-10 Refrigerator
True, model: gdm-35. Can some one please tell me where the starter for the floursent tube lights located? T
front panel at top - 2 starters, one for top panel, one for internal lights. early cocacola models had them inside the bottom panel on the right, and some later models had electronic ballasts (no starters) in the centre under the bottom of the fridge.
May 06, 2014 | Refrigerators
What size light bulb for a GDM 12 coke fridge
  • Safety shielded fluorescent interior lighting.
  • Cabinet lighting utilizes electronic ballast and T-8 bulbs for brighter illumination, longer bulb life and increased energy
  • Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
    Mar 05, 2014 | True GDM-12 Refrigerator Commercial
    I NEED A WIRING DIAGRAM FOR A TRUE FREEZERG M# T-35F
    only way to get the exact one is to contact Ture at truemfg.com. They will ask for model and serial and send it to you.
    Hope this helps.
    Mar 16, 2010 | True 35 cu. ft. / 991 liter Commercial...
    True Freezer- The 5 amp circuit breaker trips when the light on
    I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
    Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
