Bizhub 501 error codes
Troubleshoot error code c-3805
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
Posted on Mar 10, 2008
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Posted on Jun 05, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
HOW DO I CLEAR C3806 ERROR CODE ON BIZHUB 501? PLEASE FORWARD ALL DIAGNOSIS CODE
Fusing main temperature low sensing.
clean TH1-Thermistor.
Power ON machine by pressing Utility Button.
and hold for 15 to 20 seconds.
Touch TROUBLERESET once appear.
now restart machine from main Power which is under Toner Door
Dec 21, 2016 | Konica Minolta Bizhub 501 Copier
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Konica Minolta BizHub 360 361 420 421 500...
I have one photocopier bizhub 501 and have error code 2801/03..Can you help me? thnx
Take the toner bottle out. Then you will need to remove several cover to gain access to the sensor way in the back of the where the toner bottle goes and clean that sensor. might even need replacing.
Aug 25, 2015 | Konica Minolta Bizhub 501 Copier
C0501
The 501 code is not for bizhub 350 is for dialta 250/350/2510 and refer to fusing unit error.
Dec 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Oct 05, 2013 | Konica Minolta Bizhub 501 Copier
Bizhub 501 error codes c3801
Maybe the power it's not correct.Try to reset hold utility key and power on hold the utility and on screen will be show the ikon trouble reset push it and will show ok power of and on again
Apr 29, 2013 | Konica Minolta Bizhub 501 Copier
My konica minolita bizhub 501 is showing the error code C3501. How do I fix this?
if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
ENSURE YOU WAIT 10 SECONDS
1.
Turn OFF the main power switch. (Located inside machine) Leave control power switch in the on position.)
2.Turn main power switch ON while pressing the Utility/Counter key.
3.Touch [Trouble Reset].
4.Check to make sure that [OK] is displayed and the it has been reset.
5.After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Oct 12, 2012 | Konica Minolta Bizhub 501 Copier
Error code C-11C0. Can anybody help?
C11C0 Punch Motor malfunction See FS-501, FS-603 or FS-514 Service Manual.
Feb 25, 2009 | Konica Minolta bizhub C250 All-In-One...
16 people viewed this question
jasbo
jasbo
