Question about Kenmore Kitchen Ranges
Managemylife I HAVE AN ELECTRIC RANGE BOUGHT 2YRS AGO. THE OVEN DOESN'T GET HOT WHEN PRESSING THE BAKING MODE.ONLY WHEN I PRESS THE BROIL MODE.NOT SURE WHY
  • 957 Answers
The top heating element comes on when you call for broil and your bottom comes on when you are set to bake. If the bottom one is not coming on when you set to bake then it is most likely bad and needs to be replaced.
Posted on May 06, 2014
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
When baking bread in my Kenmore electric range (9435) the loaves on the bottom rack burn on the bottom and the ones on the higher rack take almost 2X as long to cook
In an electric range, the ideal place for baking is the middle shelf. there are temperature differences within the oven cavity. On the bottom shelf the heating elements actually "broil" the bottom of the pan. In the upper part of the oven, the temperature is lower, being blocked by the lower pans. A convection style oven is more ideal for bread baking.
Aug 23, 2009 | Kitchen Ranges
Whirpool electric range - RF196LXMQ - Will not reach 350 degrees
When using Broil, it is normal for only the top element to work and it depends on the oven whether both should be on or not for baking but typically, baking does not use the upper element otherwise it could burn baked goods.
If setting the temperature higher than 350 does not cause the lower element to turn on, then it's likely that the thermostat has failed and can no longer respond to the temperature set.
The fact that both elements work under some conditions means that both of the heater elements are working at least some of the time. Because of the primitive nature of the elements, it isn't possible for them to just become 'weak' but they can interrupt themselves if there is a break in the resistance element but you could only separate the two possibilities by measuring the hot coil and that would be difficult unless you can pull the range out and access the AC feed lines that go to the element. Obviously, the power would have to be disconnected and the measurement done quickly so the element didn't have time to cool and regain continuity.
Nov 27, 2008 | Whirlpool RF364 Electric Kitchen Range
Oven top element does not come on when baking
the top element is for broil only. if you have convection mode try that
Nov 25, 2008 | Hotpoint RB757 Electric Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
there are relays on the oven control that turn the elements on and off, sounds like you need a new control
Feb 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
