Question about Refrigerators
True, model: gdm-35. Can some one please tell me where the starter for the floursent tube lights located? T
  • Refrigerators Master
  • 884 Answers
Front panel at top - 2 starters, one for top panel, one for internal lights. early cocacola models had them inside the bottom panel on the right, and some later models had electronic ballasts (no starters) in the centre under the bottom of the fridge.
Posted on May 07, 2014
I had True Refrigerator model GDM 06, It was cold and freed all my stuffs. I try to adjust temperature warmer, but unable to locate the temperature controller. Please help. Thanks
I had the same thing happen to me and all I needed to do was vacuum the coils of refrigerator. Try this 1st. Thank you. Please leave feedback
Jul 10, 2016 | True Refrigerators
Make: true, model: gdm-35, can someone please tell me where the stater for fluorescent lights are? Thank you in advance :)
Not sure what a GDM 35 is but if it has a ballast, take the back off and look for a module with wires coming and going.
May 06, 2014 | Refrigerators
Model GDM-69
A GDM 69 three doors. Each door closes using a string attached to a weight, which runs through pulleys or copper tubing, and is held to the top of door. The pulleys or copper tubing can be accessed by removing the aluminum siding located inside cabinet on either side. The left side contains the pulley and weightfs or left and center door, the right for right door (each held on by 4 1/4 screws) . To make the door close, simply make sure string is attached to weight, running though pulley, and attached to top of door.
Nov 07, 2013 | True Refrigerators
GDM41 lights don't work, replaced bulbs still don't work
You need to change the light capacitor its small silver can located right next to the light tube
Jan 10, 2013 | True GDM-12 Refrigerator Commercial
I NEED A WIRING DIAGRAM FOR A TRUE FREEZERG M# T-35F
only way to get the exact one is to contact Ture at truemfg.com. They will ask for model and serial and send it to you.
Hope this helps.
Mar 16, 2010 | True 35 cu. ft. / 991 liter Commercial...
GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Where do i find the starters for the florescent lights on a true gdm-72
They should be located under the front access cover below the door. Under that cover there may be another smaller covered box that they may be located in.Make sure you disconnect the power source before removing any covers.
Nov 12, 2009 | True GDM-72 Refrigerator
Replacing a temp control valve on a true GDM 26 commercial refridgerator
Unplug the unit & remove the plate holding the thermostat. The capillary for the thermostat will go into a very small tube that runs into the evaporator coil. You will probably not be able to see the tube but will have to feel for it and get a good orientation for where it is located before you pull the capillary out. Try to measure the amount of capillary in the tube as you pull it out so you know how far you have to push the new one in and put some kind of tape or mark on the new capillary before you try to push it in. you might have to soap up the capillary to get it to slide easier.
Aug 24, 2008 | True GDM-26 Refrigerator
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
