Question about Craftsman 1323903 Battery 1700mAh, 19.2V, Ni-Cd
How do I deep cycle my battery - Craftsman 1323903 Battery 1700mAh, 19.2V, Ni-Cd
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 55 Answers
Run it until the tool stops and then fully charge it again. Repeat a few times. If the battery has a short life, you may have some cells going bad.
Posted on Jul 27, 2014
Can i replace the AGM batteries in my Bombardier class e, with deep cycle batteries?
A deep cycle battery for personal mobility equipment would be how to look into this. The AGM is a type of deep cycle battery. A gel battery is what was more common before AGM came along. Gel batteries tend to hold up a touch more than AGM.
Oct 12, 2014 | Health & Beauty
How do I know what battery to buy and how do I hook it up to my gulfstream coach
Above all, buy the best battery you can afford. You can't have too much battery! A standard sealed lead-acid battery is okay for the engine, but I would suggest an AGM battery for the coach. AGMs are longer lasting, charge quicker and can stand abuse. Make sure it is a deep cycle battery for a RV, NOT A MARINE TYPE DEEP CYCLE. Marine type deep-cycle batteries are designed to start engines along with their deep-cycle capabilities. They WILL NOT last in an RV.
Make sure the replacement is the same design i.e. + post on left (or whichever). Compare to original battery. Switch breaker off for coach. Replace battery. Hook up the RED cable to + FIRST, then black cable to ground. Switch power back on. You can charge it if you want to, but I never noticed any need.
Sep 29, 2014 | RVs
Is a deep cycle battery the same as an RV/marine battery?
Deep cycle is typically for long duration loads like lights or a troling motor but not very high starting currents. Unless marked, an RV battery is a combination starting running battery. It may have a higher starting current than the deep cycle, but not as long of a run time.
Sep 21, 2014 | Boating
Is century PS12120L deep cycle? Can it be fully discharged frequently?
all the jump starts i have seen have a deep cycle battery that is sealed - i would not run something like an air compressor motor with low voltage - it can be discharged almost flat , but do not leave it long before charging back up - low voltage =high amps on motors
Jul 19, 2014 | Energizer All-in-One 12V Jumpstarter Air...
Rascal scooter
Battery Voltage is usually always 12, Amperage can vary slightly with no major problems. 35 Amp is standard and will not present any problems.
Jan 28, 2014 | Health & Beauty
Just purchased 1985 pace motor home it has one deep cycle battery and one regular side post battery. I charged the deep cycle and the motor barely turns over, wondering if I am supposed to have two deep...
Hi, the deep cycle battery is for the home part and should charge through the external connector port. The regular battery is for the engine. Is the regular battery charged up too?
Jan 01, 2011 | Chrysler E-Class Cars & Trucks
I have a 1000 Watt Inverter, along with a regular car battery when the electricity goes out; Question: Can I use the 1000 Watt inverter and connect a 100 amp, deep cycle battery? I use regular house...
Yes, just be sure connections are heavy enough wire, and obviously the inverter uses 12 vdc input. Hook jumper wires positive to positive, negative to negative, on all 12 volt batteries. Deep cycle batteries will work better than car batteries. Just remember, when re-charging them, that they last longer when charged slowly, so don't use a high amp setting on charger and to monitor them closely, and do it in a well ventilated area, away from any ignition sources.
Apr 14, 2010 | Schumacher 1000 Watt Inverter with 2 GA....
Tech Question
Automotive batteries are usually adequate for small inverters, (< 500 Watts). When used in a car, we suggest you run the vehicle of your engine occasionally while operating your inverter. If you use the inverter while the engine is off, you should start the engine regularly and let it run to charge the battery. Deep Cycle (marine) batteries are best for larger inverters as they are designed for several hundred charge/discharge cycles. (Automotive batteries wear out much more quickly after heavy discharge).
Aug 27, 2008 | Whistler Power Inverter
Craftsman 1323903 Battery 1700mAh, 19.2V, Ni-Cd Logo
67 people viewed this question
Top Craftsman Electronics - Others Experts
Are you a Craftsman Electronics - Other Expert? Answer questions, earn points and help others
