Question about Audi Vehicle Parts & Accessories
Where is the cam shaft sensor located on a 1998 Mercury Mountaineer 5.0l
  • 3 Answers
Diagrams is not the best on my system. It says towards the rear of the engine but the connector picture shows it close to the front of the car, mid way in the engine. Shows to have a black/white wire and one that shows to be shielded. It has one bolt holding it in place. Hope that helps.
Posted on May 06, 2014
Any ideas why a 1998 Mercury Grand Marquis would just suddenly stop running in the middle of the highway going 55 mph and w a half tank of gas in it and now turns over but wont actually start again?
first suggestion is broken timing belt
second is failed crank shaft position sensor
third is failed cam shaft position sensor
forth is failed ignition control module
fifth is faulty ECM or power fuses to the ignition, ecm
Mar 23, 2017 | 1998 Mercury Grand Marquis
Where is fuel rail pressure sensor high input located on a mercury mountaineer
If you are talking about a trouble code for the pressure sensor, the sensor may be telling the computer the fuel pressure is too high. The sensor is mounted in the fuel rail on the engine.
Aug 25, 2014 | 2004 Mercury Mountaineer
How often do i change the oil on a mercury mountaineer 2005?
It depends on how many miles you drive annually, the environment your vehicle is driven in (dusty, hot, cold, humid, dry, etc), the type of oil you use (conventional, synthetic blend, or full synthetic), and the condition of your car's engine. You should consult your owner's manual and the data on your engine oil.
I drive a 1999 Mercury Mountaineer 5,0L and drive it about 1,500 miles annually. I use a synthetic blend oil and change my oil and oil filter twice a year. I change the oil in the spring so I have fresh oil for the hot summer driving season and I change my truck's oil in the fall after the hot summer driving season. Because my Mountaineer has a lot of miles on it, I use thinner oil in the winter 5/20 and thicker oil in the summer 10/20. I check my oil regularly and look at the color and feel the oil for grit. This has worked for me for many years and I have had good performance from my vehicles.
You can go on the different oil manufacture's websites and read their recommendations as well. There has been much debate about when to change the oil in a vehicle so you have to decide for yourself what schedule you want to follow.
Jun 25, 2014 | 2005 Mercury Mountaineer
Clicking noise when car is running 2004 mercury mountaineer
If your engine has the letters DOHC on the manifold, contact your dealer with your VIN#. If the sound disappears when the rpm approaches 2000 its the CAM PHASERS. The engines need the factory oil and filter and the cam parts can mess up without them. There is a recall with year and mileage limits.
Jan 01, 2010 | 1998 Mercury Mountaineer
Where is the throttle position sensor located on a 2004 Mercury Mountaineer (4.6L)?
Remove your air intake hose at throttle body opening. Look at plate across front of the opening, the shaft in the center that it is attached to, will have your TP sensor on the end of it, at the outside of the housing. This may help. (picture)7fc7240.jpg
Oct 27, 2009 | 2004 Mercury Mountaineer
Rear right cam shaft tensioner installation 2002 mercury mountaineer 4.0 2wd non flex fuel how to install
This is not easy. I would suggest removing the engine. It is much easier to do when the engine is on an engine stand.
Sep 07, 2009 | 2002 Mercury Mountaineer
I could not find the speed sensor location on my 98 mercury mountaineer. Where is it?
The Output Shaft Speed Sensor is located at the lefthand, (sitting in the driver's seat) rear of the transmission.
Jul 18, 2009 | 1998 Mercury Mountaineer
Can anyone help with an intermittent starting issue with a '98 mercury mountaineer?
If the motor turns over, but not start. Have the "crank shaft sensor" checked/replaced Ford part# 184768 $27.98 parts $230.00 labor). I chased this problem for several years. The crank sensor finally failed completely and the mechanic was able to find the problem.
Good luck
Jan 12, 2009 | 1998 Mercury Mountaineer
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Audi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ray gallant
Tom
Are you an Audi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
