Question about Digi home DV940B
Digihome Freeview Set Top Box Recorder says fail when it is switched on, does this mean it is totally broken or can I fix it ?
3 Suggested Answers
SOURCE: user manual digihome dtr80
There are two versions of the digihome dtr80 which are made by Vestel. If you look underneath at the product sticker you will find one of three numbers:
T810 : In this case youve been conned into buying a digihome pvr80. This has very limited functions and cannot series link.
T816 : This does support series link but you need to install new firmware using a computer a a serial extension cable. You can get the firmware from here: http://www.futaura.co.uk/vestel.html You want version 6.8. Bear in mind there areside affects to this program such as recording every episode that comes along on that channel and a very sluggish interface.
T825 : This does support series link by default. You go to the epg, highlight the program you want to record, Press the OK button and a menu will appear. Select series link.
Please be aware series link only stays active for 13 weeks so you will have to redo it halfway though a series.
Posted on Jun 29, 2009
SOURCE: Hi guys i bought a Digihome DG250DTRA08 freeview
Did you get one ? - if not I will copy and send.
jrb
Posted on Apr 07, 2010
I have a SIGNALEX 10 in 1 remote control but need the code for the Digihome DG250DTRA08 freeview hard disc recorder can anyone help
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 07, 2014 | Televison & Video
I have a 22" digihome LCD TV with built in DVD. At 3am every morning the DVD activates and buzzes away. The screen doesn't come on but there is a loud click as the speakers activate. How can I stop this...
3am is the freeview box update time it will do this every day at 3am the loud click you hear you should not hear it but it may be the update switch that turns the tv out of standby for the freeview to be updated its a different switch that turn this on and may be sticking.
Oct 02, 2013 | Digihome LCD TV
I have just bought a Digihome pvr320sd tv recorder with freeview, can i set it up as a tv recorder only without the freeview as i already have built in freeview on my tv.
When you set up the recorder Freeview stations will be stored. This means that you can record TV stations without watching them. So you can say watch BBC1 on your TV and record a program on Channel Four. You need the recorder set up with Freeview to recorder channels. Otherwise you would have to have your TV on and recorder set to record via the scart lead. Which would be not great quality and messy.
You should be able to loop the aerial lead so that both the TV and recorder can get the signals from your aerial, if that's what is bothering you.
Dec 22, 2012 | Televison & Video
I want an instruction manual for an Hitachi HDR505 set top box
My Hitachi freeview + recorder hdr505 keeps freezing when i go to tv guild to set to record programs
Mar 31, 2012 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
May 07, 2010 | Televison & Video
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
May 05, 2010 | Televison & Video
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Installation code tv set top box
try 1 2 3 4 universal settings works with mine
Mar 02, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Digi home DV940B Logo
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
