Question about Singer Sewing Machines
How on a portable singer sewing machine how to put the tensoin back together?
My sewing machines tension is took apart how do I put it back together I have never been able to find out how .could you tell me how?
    Problem Solver:
  • 12 Answers
That is much too complicated to type an answer here. You really need to find a SEW&VAC store and have them repair it.
Posted on May 06, 2014
maklean
  • 1665 Answers
SOURCE: help!
Have a look at link it may helps
http://www.repairsewingmachine.com/
Posted on Aug 09, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
  • 30 Answers
SOURCE: I have a singer Samba 6 sewing machine and it has
Try this link to order manual.
http://www.singerco.com/accessories/manuals.html
Posted on Sep 25, 2009
  • 255 Answers
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Posted on Aug 02, 2010
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
How can i reassemble the lower case of my singer 2010 superb sewing machine
Most machines you have to put things together and take them apart in a specific order. Look for tabs that fit in specific holes. Also most of the time the parts that go over the motor go first, then front sections and then the back. You can contact singer directly and they can walk you through it in a live chat. Otherwise I have had really good luck working with the people at the link I attached. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Dec 09, 2014 | Singer Superb 2010.CL Sewing Machine
How do I put my foot controller back together, I took it apart because it will not turn off. My model # 66 - AA307535. Controller # 192257
more than likely, your variable resistor in the foot pedal is shot. cleaning is a low probability repair. replace the pedal assembly.
Oct 19, 2014 | Singer Sewing Machines
Quantum Manual
Please see the link:
http://www.sewingpartsonline.com/singer-quantum-xl150-sewing-machine-parts.aspx
Nov 18, 2013 | Singer Sewing Machines
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
Tension control on older sewing machine.
Better off taking it into a reputable sewing center to rebuild
Aug 22, 2009 | Sewing Machines
Jun 18, 2009 | Singer Featherweight II 117
Sewing Machines Logo
115 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
